ATC350x wider bolt on footpegs
These are wider bolt on footpegs for your stock 85-86 ATC350x pegs. They can be mounted using your stock hole locations or you can drill you pegs to accomodate where you would like to put them. They make the pegs 2 3/8" wide compared to 1" stock. They come with mounting hardware. Some spacers will need to be ground a bit to fit in the middle of the pegs. The pegs are made from 304L 12ga stainless steel and they are nice and strong!! They can be modified to have sharp edges if needed as this as been requested by ice racers from time to time.
More...
//ArrowChat Integreation Code
