Ok now that i got your attention. I had to replace the rear carrier and axle on my 83 200e due to PO abuse. Currently I have what I was told is an 83 185s carrier and brake drum and a 200e axle. New bearings and brake shoes. Problem is I've got about an 1/8 - 3/16 of slop from side to side with the axle inside the carrier when I grab the rear and shimmy it back and forth. Loosened both nuts and pushed axle all the way over and re-tightened. Still moving!
Are carrier and axle not compatible? I was told they were. Secondly i have the brakes adjusted all the way out at the lever and turned all the way in on the carrier. Brakes are grabbing but not enough. Brake drum too worn? Wrong alignment of lever on carrier? Help me out guys I need some answers!
Trikes Currently Owned:
