Thread: Clutch Slipping on 81 Honda 200 ATC
    Popeye is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2011
    MS
    301
    The clutch is slipping on my 200 ATC. It does it the worst on take-off, so I went ahead and ordered a centrifugal clutch. But it also slips when shifting into 3rd, 4th, and sometimes 5th gear. Do I need to replace the manual clutch as well? If so, should I order a whole new basket or should I just go with the plates and springs from EBC?
    Thanks for any help!
    Brian
    Jan 2011
    Avon, Minnesota
    641
    i dont think you can get the basket... while you are in the clutch take a look at the fiber plates for wear. it's problay just your centrifugal clutch slipping when you are getting on the the throttle from gear to gear.
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
    Sarnia, Ontario, Canada
    3,415
    'yamaha driver' may be right on that, but the 411 I have received is that usually centrifugal clutch will slip on initial take off, secondary clutch wear is what causes the high gear shift slip..
    but then they are both bathed in the same oil..if lack of maintenance is what caused it then they are probably both NFG!!
    you already ordered the more expensive of the two, buy the secondary set and put them in also since you are in the same area..no point in doing it twice.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Scootertrash's Avatar
    In the sticks
    4,638
    Did you try adjusting the clutch at all? I only ask because you didn't specify if you did or not. Also I've heard that if you don't use a motorcycle oil specifically for wet clutches your clutch can slip.
    +1 to what Doug said. If you are going to do it, do it right the first time and check/repair both while you have the cover off.
    Oct 2011
    MS
    301
    Yea, I was figuring on going ahead and doing both anyways. The problem probably is from lack of maintenance. The bike is in good shape, but I've only had it a year. I did adjust the clutch though and it didn't help. I paid $40 for the centrifugal and I found a nice basket and all for around $30. I'll probably just go ahead and get it. Thanks for the advice.
    Mar 2007
    Texas
    5,045
    yea replace them both, but do not use the used plates, get new ones as the used ones are probebly worn as well.
    ________________
    https://www.mikesatvfix.com
