Results 1 to 2 of 2
Thread: Suzuki ALT 125 Problems! Help please
    May 2012
    Oklahoma
    Exclamation Suzuki ALT 125 Problems! Help please
    Hey everyone!
    I recently picked up my alt125 and after starting to ride it one problem has became apparent. Everytime the three wheeler warms up it begains to cut out. The missing becomes really appearent in 4th and 5th gear. The three wheeler will run fine for its first few minutes of operation. I have cleaned the carb and replaced plug any ideas what this could be? Any thoughs on this issue would be greatly appricated!
    Toaster556's Avatar
    Toaster556 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2010
    Fraiser Valley, BC, Canada
    176
    You've got an electrical issue of some sort. MonroeMike has posted service data here that should come in very handy.
    The only tool you really need is a voltmeter, either analog or digital is fine. I use the analog when possible, mostly because the one I have is an older single setting model. It makes it easy to jump from piece to piece without having to mess around with settings.
    If you need any electrical parts, I'm trying to track down my old ALT185 to see what swaps between the A/LT 125/185 and the DR100-200s
