If the plug gets too wet, it won't fire, you may have flooded it. Remove the plug and clean it, let it dry. While it's out, kick the engine over several times to clear out the combustion chamber. Put the clean plug back in, close the choke, and kick it over a few times - it should at least try to start. If it doesn't, pull the plug again and see if it's wet again - if it is, the carb is set too rich. If the plug is dry and it won't try to start, remove the intake tube from the carb, open the choke and throttle slide, and spray some carb cleaner, WD-40, or starter fluid into the carb and kick it a few times. If you've got spark, compression, and fuel, it should fire. If you're missing any one of those, it ain't gonna start.
TRX 70 - rescued from the trash
84 125m - first restoration
84 200m - now a four wheeler with 450r suspension
84 200x - restored, now my rider
83 250r - current project
Looking for an FL350 (Odyssey)
