Results 1 to 7 of 7
Thread: 350X on a 200x fork swap question
    Scootertrash's Avatar
    In the sticks
    4,628
    OK , So this is just for verification, I think I've got it right:
    If I'm going to put 350X forks on a 200X, I will need the triple trees, forks and the hub from the 350X, but the 200X rim will fit the 350X hub. Is this correct?
    Thanks in advance
    Dec 2010
    Back in VA baby!!
    711
    The 200x rim will fit the 350x hub.
    In the sticks
    4,628
    Thanks Flossy!!
    NC
    907
    What year 200x? The first gen 200x wheel will NOT fit the 350x hub.
    Manheim, PA
    5,754
    86-87 200x hub is same as 350x, if you putting it on a 1st gen you need all 350x stuff. other wise you wont.
    jdm97ek4 is offline Check My Feedback before dealing with me! Arm chair racerNew to the board
    Feb 2012
    Homer City pa
    132
    Im ready to do tjis converion as well but I have 350x forks tree caliper and I was going to use the 200x hub shouldbgo right oj they are the same length and thickness
    2005 f-250 super duty
    2004 Yamaha rhino 660
    1984 Honda ATC 200x
    1985 Honda ATC 200x
    1986 Honda ATC 350x
    2004 Ski-Doo 500ss mxz adr
    2003 Yamaha zuma 70cc liquid cooled
    Apr 2013
    Vermont
    67
    I'm kind of doing the opposite, I just got a 250sx and the guy said the whole front end was off a 350x. Turns out the wheel, hub and triple trees are, but it has 200x forks and the 350x axle has different threads so it doesn't fit. I think the forks are off a 85 or older 200x, so I was just wondering if a first gen 200x front axle would fit in a 350x hub?
