Thread: Reed Spacers
    Rittman, Ohio
    6,276
    Reed Spacers
    The theory is that they are supposed to improve low end. Has anyone used a reed spacer, that can say with any experience whether the spacer alone makes any difference? Mosy guys who use spacers do so when they also change reeds, and cant determine whether their gains were realized by the reeds, or by the spacer.
    Roanoke, VA
    4,038
    I rode my brothers 250R before and after he put his in and I could tell a bit of difference on lw end. On this one trail, I didn't have to shift from 3rd to 2nd for the first time going up it and during drag races it started to pull right off the line. I'd say a max of 1-3 HP difference on the bottom end.
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
    Oswego NY
    1,935
    TIM.
    I put a V-Force Delta system into my TECATE. V-Force has a built in reed spacer, it is alot thicker than stock. I noticed a gain in lowend also, but I cant tell if its the thickness or the reeds. All I can tell you is that I will have V-Force in the next TECATE!!
    LATER
    MIK6 / Mike
    New England Ride 4/13
    Hey MIK6,
    On that V-Force Delta is there any other modds that have to be done to the motor. Like having to move the carb back to allow for the thicker spacer? Or changing the jets or air/fuel mixture?
    How much do they run for and who sells them?
    I'm looking to put some upgrades on my tecate but the future wife has both hands on my money.
    Nov 2002
    199
    Then you better tell her to recognize who's money that is!!!
    <center><B>1)</B>1983 250r <B>2)</B>1984 200s <B>3)</B>1982 185s Rebuild Project.
    .:: Building 86 250r or cr500r or cr250r or ... sigh ::.
    .::Visit www.MidWestTrikers.com trikes! ::.</center>
    Oswego NY
    1,935
    CHRIS
    I didn't have to do anything to the carb. I run a stock 85 T3 carb that has been bored to 38 1/2mm, as big as it can go. It has had the jetting changed already. You will not have to move the airbox, it is only about 3/8th thick. The rubber boots will take up the difference, but they are harder to get on. You can get a V-force system anywhere, but they are not cheep. Between $120 and $150, but you do get more power w/ them.
    GOOD LUCK
    MIK6 / Mike
