Results 1 to 15 of 69
Thread: Tri-Shee Build Thread. A.K.A. Trish
    Dec 2007
    Southwestern NY
    517
    This whole build started simply because I could. I have been hoarding banshee and Tri-Z parts for years now, and have accumulated quite the pile of spare parts. I had a Tri-Z frame with a junk engine cradle, and I had a spare banshee frame kickin around....not to mention a complete Banshee with a 400 stroked and ported engine.....and so it began.
    On April 7th of this year, I showed up at ATCTim's garage with my 2 spare frames, a whole pile of parts, and a big Idea.
ID:	149652Click image for larger version.
ID:	149653Click image for larger version.
    We started by hacking off the front of the banshee frame, and the top half of the Tri-Z frame. Then proceeded to ZIP-TYE the 2 frames together until we got an Idea of how this was gonna work out...And we realized real quick, that this was almost meant to be. We basically grafted the top half of a tri-z frame to the back half of a banshee frame.
    We then built the engine cradle around the engine. We had to piece the engine cradle together with several pieces canibalized from the old Z frame, the old banshee frame, and even a Mini chopper frame...LOL. A "friend" was supposed to bend us up the cradle with his "sweet" pipe bender, but it seems he was too busy to help...ever. The down tube is actually a Honda 185s fork tube (BAHahahahaa....who knew a Honda could be good for something! j/k)
ID:	149620Click image for larger version.
ID:	149621Click image for larger version.
    All the joints have slugs in them and are beautifully Tig welded, thanx to Jake the Snake and Chuck (UpChuck Racing). I ground all the welds with a cookie wheel, then inspected for any pits...ALL pits were then filled, and the joints were hand flat filed by me, until they were no longer noticeable. Those who have seen it, know, its almost impossible to see the seems.
ID:	149656Click image for larger version.
ID:	149657Click image for larger version.
    If you look close, the frame is built offset, just like the banshee frame is...the down tube is centered, but the cradle is not. you can see it real good in a few shots. It has to be built like this to have correct chain allignment, being that these engines were designed for a street bike. These engines also "lay down" alot more than the tri-z engine, so we had to raise the front of the engine about an inch so that the cylinders were IN the cradle....
ID:	149623Click image for larger version.
ID:	149624Click image for larger version.
    Then we added some cross bracing to the lower engine cradle, just to make sure we didn't twist her up like a pretzel the first time 70 ponies ripped threw her!
ID:	149626Click image for larger version.
    We added a few gussets in the banshee sub-frame, since in my experience, they bend like hot butter! The seat latch was cut from the banshee frame, trimmed, and grafted to the top of the Z frame. The angle of the seat is almost perfect. I trimmed about a 1/4 from the front sides to make it as close as possible. The radiator brackets were ever so slightly modified to move the radiators forward and up 1/2" (head clearance).
ID:	149628Click image for larger version.
ID:	149629Click image for larger version.
    SAY IT!!!!!
    85 1/2 Tri-Z - The Trail Bike w/Inverts
    85 Tri-Z - The wifes Bike
    85 Tri-Z - The MX/ICE Bike, 310 w/Inverts
    12 Tri-Shee - The Flat Track/TT Bike w/Inverts
    NYTRO - New York Trike Racing Outlaws - COME GIT SOME!
    Dec 2007
    Southwestern NY
    517
    Chuck hauled everything to his "shop", sandblasted all the parts, and had them beautifully powdercoated KTM orange. The powder came out flawless!
ID:	149632Click image for larger version.
ID:	149633Click image for larger version.
    I then started assembling this creation with parts from just about everything in my garage...and some others.
ID:	149635Click image for larger version.
ID:	149636Click image for larger version.
ID:	149637Click image for larger version.
ID:	149638Click image for larger version.
    The engine was pulled right out of my quad, freshened up, and stuffed into Trish. It is a 4mil stroker with a F.A.S.T. racing formula port, stock bore cylinders, 20cc domes (100 octaine), VF3s, Chariotte intakes, and 30mm PWK carbs. In quad form, this thing HAULED THE MAIL! We built another under cover top mount tank, almost identical to the one on my race bike....Only this one has (2) 1/4 outlets, so I don't run the float bowls dry at the strip.
ID:	149640Click image for larger version.
ID:	149641Click image for larger version.
    Then it was off to DYNOPORT to have a custom pipe built. I went over what I thought would work for a 2-1-2 inframe pipe with Rich, then let him work his magic! I brought him a pair of FMF shorties to work with ( I LOVE the sound of the shorties). When I showed up a week later to retrieve my bike...I WAS FLOARED!!! I NEVER expected it to be as PERFECT as it is...I will let the pictures tell the rest
ID:	149643Click image for larger version.
ID:	149644Click image for larger version.
ID:	149645Click image for larger version.
ID:	149646Click image for larger version.
ID:	149647Click image for larger version.
    And some pics of her at TF:
ID:	149649Click image for larger version.
ID:	149650Click image for larger version.
    SAY IT!!!!!
    Dec 2007
    Southwestern NY
    517
    I let QUITE a few people ride Trish at TF, and believe it or not, this is a VERY trailable bike. I trail rode this thing all week at TF on a -1 swinger. WHAT A BLAST!!! Enough low end to ride threw the woods at a leisure pace, AND ENOUGH POWER ON THE PIPE TO PASS ANYTHING! And, with regular old coolant, stock tri-z rads, and a t-stat eliminator, she runs around 170deg in the woods, and never broke 195deg at the drag strip. Trish is my new trail bike!
    Then, the night before the drags, we threw the +6 in her with some 22" 4-snows. The next day, we let her eat!!! I Took home the first place trophy and the $200 cash in open class at the drag strip! (also took 2nd in mod class with my 310 Dream Z). YEP, this is my FAVORITE TRIKE YET!!!
    OK boys, let me know what ya think. Ill get better finished pics of her later...
    SAY IT!!!!!
    Lewiston, N.Y.
    1,477
    im not a yami guy by any means but this is cool! It shows that anything is possible once them creative juices get flowing and you def succeeded. Truthfully it looks factory and not cobbed together. Outstanding buddy!
    Jun 2011
    southern california
    125
    holy jesus i am a yami guy and that is one of the sickest things i have ever seen its a work of art
    please tell me you have some vids
    Mar 2008
    EastGreenbush, newyork
    3,494
    very nice work man. that looks to be one mean machine!! to bad i wasnt there to take it for a rip! amazing amount of welding on that pipe!! I can see why it would be your fave, but the Dream Z is hard to beat!!
    sinsayers's Avatar
    sinsayers is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2010
    wv
    169
    All of these super nice trikes popping up on 3WW recently have my brain fried. That is sweet and the pipes are very nice, I can tell by all of the details you worked hard on her man. Great trike
    1985 ATC 200X <Stock>
    1985 250 ES Big Red
    triplejssportinggoods.com
    Oct 2011
    Manchester england
    135
    AWESOME AWESOME AWESOME. that's my dream trike. Do you still have the specs for the pipe or do you fancy making another to ship to me in uk? That's the only thing that's been stopping me making one.
    NEPA
    7,048
    Excellent work! Also not a Yammi fan at all. But that is a beautiful ride to be very proud of!! The two of them together is perfect! 2 pieces to be Very proud of !!
    Tionesta, PA
    5,735
    Let me be honest here: when the banshee and tri-z frames showed up in my garage and were both cut - I was the biggest nay-sayer there was. I just could not picture in my head this thing working. That being said, I know Jon is a perfectionist, and figured he would come to a point and say - it's not gonna work. As it developed, my mind was changed. Plenty of Yamaha / Honda jokes and trash talking went into this project. I'm just happy it has a bit of red in it (LOL - 185S fork in the frame )
    Seeing how this came together with the talent in my shop - I am not afraid to dream up anything now. With 2 AWESOME welders - powder coating and machine shop at Chuck's disposal and imaginations that sometimes need reeled back in - I can't wait to see what is rolled out my overhead door next.
    I got to ride it at TF and was astounded by it's low end grunt - with only ever riding one banshee before my entire life, it was a pleasant surprise. This trike really could compete in any trike event. Watch out boys - there is a new sheriff in town!
    Great build Jon! I <3 Trish!
    May 2012
    Harsens Island, MI
    229
    WOW!!! what an amazing build!! you guys r some damn good welders!! your next build u guys should and probably could start with tube stock and build the frame from scratch,lol!! congrats again guys!!!!
    Jul 2011
    Lilly PA
    1,480
    I fell in love with this machine at TF and loved watching her tear up the strip. Awesome job Jon and hope you still plan on hitting Beaverdale this year with us on Sept. 9th.
    Just sit back and chillaxx
    Dec 2007
    Southwestern NY
    517
    Yeah, I forgot to mention that the biggest "nay-sayer" here was the founder of Tionesta Trikes himself!! But without ALL their help, it wouldn't have been possible. I can't say thanx enough...BIG THANX: Tionesta Trikes (Tim and Jake Kiester), UpChuck Racing (Chuck Seitz), The Birts (Jeremiah and Hoyte Birt...these guys built my fuel tanks), Tri-ZNate (Nate Carey, for donating a swinger for the drags) and DYNOPORT for that GORGEOUS pipe, that obviously performs as well as it looks!!!
    Oh, and Rich @ DYNOPORT said that this was a 1 time pipe! He had so much time into it, he said would have to charge $1500 to build another one, just to make some money on it!!!
    SAY IT!!!!!
    Maryland
    3,077
    Very impressive build John.
    I got to ride it guys, and I'll tell you what impressed me the most was how mild natured it was if you wanted it to be. Big power is awesome but big power hidden behind a nice time cruise-able machine is even better. You could literally cruise this machine in the trails all day. Very impressive.
    Dec 2011
    Grand Rapids, MI.
    680
    That is a sweet z, I also really like the orange and blue. I only hope to have as nice of a trike as this eventually.
    1986 KLT 185
    1984 200S
