I think the tri z radiator shrouds may even be a close fit on that beast, very cool indeed. I wonder how it handles.
Sent from my iPad using Tapatalk
My toys 85 KXT250A2, 85 ATC250R, 85 Tri-z 250, 06 LT-R450, 04 YFZ450S, 07 125 typhoon x 3, 06 FPV GT.
Lots of air cooled trikes have shrouds, but I was talking about looks, and I think some blue trimmed TRI-Z shrouds would complement that "TRI-B"nicely
I'm not even sure how you'd go about mounting them though. You'd have to tap holes into the frame and then your angles might be off. Even though the z frame is similar. So it might work.
If anything brackets would be the way to go but I'm not sure how it'd look. I mean tri-z shrouds are side mounted anyways. Not tank mounted like a 200x. I'd give it a try if it were mine. It would really set the look of a blaster/tri-z child.
Been begging the wife to let me buy a Blaster and a first generation X and slide the motor into the X frame... my dream Trike!!!!
I put one in a trimoto 125 with a 175 front end, it was fast but with no rear suspension it wasn't the greatest, I think the blaster motor would be perfect in a 200x
3 wheelaholic
ATC200/CR480 custom
1984 atc250r near mint
wr450f trike on the way
Trizinger for my sons
Friend of mine has acquired a very interesting set up. Let's see if i can get this right..
YT175.. originally.
YT tranny and cases. Blaster 57mm crank, Blaster 240 big bore kit, blaster flywheel/machined for pull start. YT175 bassani pipe. Blaster ignition.
5 speed auto clutch 240cc Trimoto.
I've been wanting to place a Blaster motor and swing arm in a YT175 for some time. With the motor and the swing arm bolting up to each other.. chain alignment, can't mess up!. The kicker to this, is the kicker. But if the flywheel can be machined(drilled and tapped) to accept a pull start, then why not? A 200x would be a better starting place.
