WOT (main jet), then midrange (slide needle position), then 1/4 throttle or less (pilot jet)....
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 200ES Big Red
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
ok thanks ride red
yup yes sir thankyou
I'm a traditionalist, so I vote RED as well!!
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
yeah same..thanks again ride red long time no see lol
You running a shorty lever??? If yes, switch to a full length clutch lever. That will make the clutch easier to pull.
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
Is the play between the carrier and swingarm, or between the axle and carrier?
Are you sure you aren't mistaking bad swingarm pivot bearings for play in the axle??
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
I also have the Durablue +4 on mine. I also have ITP rims with more offset than the stock R rims making my R a total of 6" wider than stock.
I rarely "trail ride" my R. I ride almost exclusively on seasonal gravel roads in Lewis County (Tug Hill) where there are long straights and sweeping curves. I absolutely LOVE how my R handles with that wide rear-end!
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
Hey there and welcome to the site. I see you have started 10 different threads with questions you have about your 250r - for future reference it is generally better to put all your questions in 1 thread if they are about the same bike even if it is different topics....much less clutter.
its the long
yeah i put 10 just to open up the sight lol
yeah mines a 6 to with rims
Get used to the heavy clutch then!! LOL!
It really is a matter of perspective...... To person A, a clutch may seem very heavy, but to person B it may seem fine.
It could also have heavy duty clutch springs in it. That would make the clutch harder to work. Only fix would be to switch to standard clutch springs.
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
3wheelers I own now: 86-ATC500R 86-KXT500 87-KXT250
Check out my 3wheeler videos on youTube Lazybiker79
http://www.youtube.com/watch?v=UNy9k...qljTifaAX47-6w
