Thread: ATC Speedo Resto - Whitening the Odo Dials
    May 2009
    S.E. Michigan
    1,251
    I recently bought a Honda ATC Speedometer. It was in ok shape, but I wanted to clean it up as much as possible. I followed a lot of the other threads about taking it all apart and everything went well.
    The problem was that my odometer 10'ths number dials were very brown, as was the needle.
Name:	IMG_0459 (Large).JPG
Name:	IMG_0463 (Large).JPG
Name:	IMG_0471 (Large).JPG
Name:	IMG_0469 (Large).JPG
    I found a website that dealt with getting rid of the brown coloration of aged white plastic. The website was primarily devoted to old computer equipment and video game consoles. The before and after pics were dramatic, so I decided to give it a shot. Here are my results:
Name:	IMG_0001 (Large).JPG
Name:	IMG_0004 (Large).JPG
Name:	IMG_0012 (Large).JPG
    The chemicals you need are simple: hydrogen peroxide (from the hair salon, which is much stronger than the drugstore variety), Oxiclean (the laundry booster), and a blacklight. I know this will sound like some crazy internet hoax, but I tried it and it worked... although I do think there are a few flaws in the website's information.
    It took three days of soaking to get my results. I first started with drug store peroxide, then switch on the next day to hair salon peroxide cut 50/50 with water, then on the third day went with hair salon peroxide cut with water at 75/25 (mostly peroxide). You mix about a 1/2 teaspoon of oxiclean into a cup of peroxide and stir. Put this in a small plastic container with your plastic parts to whiten and then stick this under a blacklight. If it is sunny out, the sun works best. You are looking for UV light here. The sun is the best source, but in Michigan this time of year, my blacklight (yes the kind you'd use at a party to make white things glow) was my best option.
    The chemicals didn't affect the black ink numbers, and did significantly whiten the plastic. I took the parts out after three days, and they are almost 100%, but they aren't perfect. I didnt' want to risk any other sort of ill effect from too long of an exposure.
    So, if you want to read more, search retr0brite on google (that is a numer zero in retro). You'll find their main site and the explanation of the science behind all this.
    I do have one problem with their information, and maybe it is due to a recent change in the formulation of Oxiclean. The website goes on to say how a particular chemical in Oxiclean, specifically TAED, is a catalyst for the peroxide and makes the process work more quickly. They claim result in 8 hours or less. I pulled up the MSDS for Oxiclean and it no longer contains TAED (no idea if it ever did, but the website claims it did). So, I used the oxiclean anyway, but I don't think it is having any effect. Given that my process took 3 days, I think that supports the thought that there is no more TAED in oxiclean. Anyway, I got decent results in 3 days, so I'm happy.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    MN
    3,263
    Very cool! I will have to try this on the next one i work on.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Apr 2002
    s.w. michigan
    6,498
    Wow, it sound interesting when you was telling about it Frank but did not exspect those results ! Thanks for sharing, this is we all learn stuff, very nice indeed
    May 2009
    S.E. Michigan
    1,251
    I was starting to get very sceptical after my first day of soaking, since I didn't really see any difference. But, I was just using 3% peroxide from the drugstore, and the site says to use at least 6%. Many of the users who posted results called out using over 10%. Since I wasn't in a rush, I figured I'd try the hair salon peroxide. Ultimately, it worked. I'm not sure how long it would have taken had I jumped straight to the 75/25 mix of peroxide/water (the stongest I tried). I'm trying some other parts now (video game parts) using the gel version of the formula. Basically, if you have a very large part, it isn't economical to fill a tub full of peroxide. So, you add some food based thickeners to make a gel, then paint it onto the suface to whiten.
    Well, I hope this helps somebody else out. I'm very happy with the results.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Lewiston, N.Y.
    1,479
    Looking Great
