I'd give him $250 all day long for that. Nice score!
Nice find and hell of a price for an 84T3 that is pretty much all there.
Just sit back and chillaxx
Great score!!!!
1986 Honda 350X
1985 Yamaha Tri-Z 250
Good deal Salty!!
great find.. wish i found it...
250r dust runner
Guy said it's an 85. I didn't see the year stuck on the steering stem near the forks. Any place to check?
it seems like theres something wrong with the clutch. No tension on the cable. The shifter moves waaay more than reasonable. It does go into the gears.....
Occasionaly, the kickstart will click and not crank the engine.
In other news, 190psi comp :-D
Thing is that you can mix up some stuff for those 2 years. I've also seen stock and 2 different style braces on the left middle motor mount as well as under the rear seat post rubbers.
86-85 swinger/85 with 86 motor. Bunch of crap.... Run the VIN but then again, who cares, just use your best parts
no doubt it's an 84. A decal showining the model year and vin would be on the downtube.the vin should be stamped into the left side of the steering neck
Yep im w ben.. 84.. drum front brake
MIK6/ Mike
New England Ride 4/13
I shall go with 84! <-- still havent looked lol
Anyways, where can i find a manual for this? Something wonky going on with the shifter and clutches, i want to check them out.
I enjoy a good tear down/ inspection.
World region:Asia
Manufactured in:Japan
Year:1984
Make:Kawasaki
Model:KXT250-A
Body style:All Terrain
Drive type:RWD
Cylinders:1 Cylinders
Good news everybody. The clutches work!! stronger than im used too.
The shifter... was very lose on there. some light stripping on the shifter, but not the shaft I've ground a little down to get this on there snugger. getting ready to put it on and see how it fits!
It shifts great!
I'm thinking about Rickys stator and flywheel combo. I read all the horrible reviews of it. But i never read about anyone using the 12v AC regulator that they state to use on the website.
My tecate has a Ricky Stator and flywheel and I believe dcreel said it has been on there for many years without a single hiccup.
'86 ATC 250R, Build Thread http://www.3wheelerworld.com/showthr...highlight=250r
'86 "Factory Tri racing" Tri-Z http://www.3wheelerworld.com/showthr...b-Top-Tank-ect
Pile of Tecate Parts
My Feedback Thread: http://www.3wheelerworld.com/showthr...edback-for-bkm
Do you have the AC voltage regulator?
