Thread: Weathered Plastic Restore!
    Wichita, Kansas
    1,361
    How I made my faded ugly plastic tank look red again.
    I grabbed me a bucket of soapy water (Dish soap). Some of the 220, 320, 400, and the 600 grit wet/dry sand paper I had left over from lapping my head, my heat gun (I prefer a propane torch) and some rags. High grit should allow for more shine. I’m OK with the matte finish (for now).
    This is simple and straight forward. Use the sand paper to sand off the faded white parts. Use the soapy water to clean the sand paper as it gets clogged up. Use the rags to wipe off the tank during sanding. Use the heat to give the tank its color.
    I did a test patch with heat and no sanding on the top of the tank. It's why you must sand first. Don't hold your heat to long over 1 spot, just enough for it to change colors for a second. You’ll burn your plastics if you do!
ID:	159798Click image for larger version.
ID:	159799Click image for larger version.
ID:	159800Click image for larger version.
ID:	159801Click image for larger version.
ID:	159802Click image for larger version.
ID:	159803Click image for larger version.
ID:	159804Click image for larger version.
ID:	159805Click image for larger version.
ID:	159806Click image for larger version.
    MN
    3,263
    That turned out nice. I have done something similar to plastics on trikes. I tried some of that renew stuff or whatever its called from the auto isle at walmart, you know that commercial where they show people wiping it on the black or dark gray trim on vehicles, that stuff actually does an ok job but armorall gives about the same effect. That plastic really whitened up, is this from normal use or a case of it sitting behind the barn for five years? LOL
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Williamstown PA
    5,825
    i used mothers polish and sanded the tank on my 85 250r. it came out nice. idk about perfect, just didnt want white.
    Sarnia, Ontario, Canada
    3,415
    I used simply SOS pads and water..removed all the oxydation and stains. Looked really good but not at a shiny plastic luster..
    If a guy was to finish off with the higher grit paper and wet sand it would come back pretty quick I think.
    You might try that next time 'rubbersalt'..you might be able to skip a few of those steps and save some time.
    I didn't think to get a before pic, but here is the after.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    ktmbk's Avatar
    ktmbk is offline At The Back Of The Pack Arm chair racerFirst time rider
    Long Island
    154
    I used to use a three step method of wet compound, I think it was made by p05 at the time. It came out ok. yours came out better
    Wichita, Kansas
    1,361
    The crustyness was extra thick on mine
    Trying to find pics of my 125 fenders i did a while back.
