Thread: honda 250 big red tires what size is best for stock suspension and height
    rouseanator's Avatar
    rouseanator is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2012
    lynden washington
    209
    I am wanting to get new tires and rims for my stock 1985 BR 250 I like the gorilla silverbacks 27 inch and the kenda executioners maybe 26 or 27 but my question is what will fit and not rub also what kind and size for the front tire and rim would like to have three matching but don't know if they will turn good please help so I don't wast money thanks
    Audio_Phill's Avatar
    Audio_Phill is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2012
    SWVA
    197
    My 200e br can handle 26's clearance wise so i imagine the 250 would too, but small bore engines aren't fans for large tires so i def recommend regearing to keep same load on engine. If you go up 12% on tire size, make the gearing reflect 12% increase in ratio.
    1986 tr200 Fatcat
    1985 ATC250es, all original but tires, need a right side cover
    1983 ATC200e All original but tires and wheels
    DG pipe, uni filter, jetted
    1983 KLY250C Prairie (for sale as parts)
    1982 ATC70 (x3)
    fingerlakesny
    2,835
    kinda hard to adjust gearing on a 85 shaft drive big red...i would just keep the 25" tires but that's me.....
    250r dust runner
    Stonewall's Avatar
    Stonewall is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2011
    Bryan, Texas
    405
    The 250ES can handle up to 27" tires without any suspension modifications, and I put a 27x12-11 Vampire on the front using a 2+5 offset rim. BUT, if you ride over 30 MPH the fenders will flop into tires and rub. If you put more than the weight of the rider on the rear rack, they will rub. Occasionally mine would grab the mudflaps and pull them under as well.
    But if it's just going to be you on the 3 wheeler, and you just plan on trail or mud riding, then they'll be fine.
    I got a really good deal on these tires, otherwise I would have stayed with 26's.
    I had these 27x12-11 Vampire TSL's on my nice 85, but I have since swapped them to my 86 because it's not quite as nice.
    1974 Honda ATC 70
    1985 Honda ATC 250 ES Big Red
    1986 Honda ATC 250 ES Big Red
    2008 Honda Rancher 420
    1983 Hustler 945-HK 6x6 - Fire Breathing 627cc V-Twin Monster
    2010 Chevy Silverado 1500 4x4 LT
    1983 GMC K10 Sierra Classic Suburban 6.2 Liter Diesel
    My Feedback:http://www.3wheelerworld.com/showthr...-for-Stonewall
    There is no Z in Diesel!!!
    Sep 2012
    lynden washington
    209
    Thanks stonewall for the pics I can now see that a 27 will fit but its pretty darn close to the fender I think I am going to try the 26 inchers prob the kenda executioner they are 6 ply and heard they last along time but ride ruff on trails but great in the mud still going to research more the bighorns they look good all around
