just pulled the plug it's a dark rust looking on the side and the very tip is very dark brown but not black.
ok i will try that thanks for your input.
your plug is going to tell you alot,make sure you dont have any crimped fuel lines or water lines ,and dont forget your fuel pump make sure its in good shape as well!
Whatcha runnin for coolant and mix...?
1985 Tri-Z-
Originally Posted by mywifeknowseverything
when say fuel pump it has had issue there you can go thru all the gears hard on 5th it will fall on its face then you let off the gas for a few seconds it picks back up but i never noticed any problems with it cruiising around
on the spark plug i just pulled it out when it was in garage no shutting it down when running. and for coolant its a 50/50 mix green coolant.
do you have alot of smoke coming out of the pipe? alot of leaking coming out of the cylinder to pipe?
warm the bike up and do a plug chop at WOT, check the plug see what its reading..
Got a compression reading on that z?
1985 Tri-Z-
yeah my other tri's don't smoke like this one. just thought maybe the previous owner put to much oil in the fuel mix in it. i was wondering if the crank seal was bad but never had this problem with any of my other tri's
Just for shits and giggles throw one of your other z's fuel pumps on this one and see what it does...
170 on compression test
i will change the pump tomorrow nothing to lose.
170 is a bit to the higher side, whatcha runnin for fuel..? suppose it could be the carb starving for fuel, i have never messed with a stock Z carb..everyone i have had in my hands had the stocker thrown out long ago. Still bit odd to overheat that quick if everything is in check, Your mag side basegasket dry or coverd in oil??
1985 Tri-Z-
