Sometimes if there is too much water it will blow out the excess. Does the red light come on also to indicate overheating or just coolant coming out overflow tube. After it over heats is there still coolant in the bottle under the seat?
Originally Posted by
oile
What did I forget to check? Replaced radiator cap, flushed radiator, installed new water pump, set timing to specs in manual with dial indicator, changed cylinder head and head gasket, ran with no thermostat also tried running with a different thermostat and still overheating within a 10 min ride time. Pushes coolant out of overflow when overheating.
Could the cylinder jug be having issues?
P.S.
Running 30/1 oil ratio
Just-Tri-It
:Trikes Owned:
1985 Tri-z's 3
1986 Tri-z
1984 YTM 200ERN 1
