Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: TRI-Z likes Reed Spacer
    Arizona
    843
    For those of you who have a TRI-Z you may want to try a reed spacer. I installed one recently and couldn't believe the performance gains. From the bottom end to the top end it is a much stronger motor. I should note that I also added a boost port (see the Wrench Report) but that was before adding the reed spacer. I added the spacer because I felt the engine wanted to gulp more air (because of the boost port) and it wasn't living up to its full potential. Well, I was right. Wow. It is a tight fit with the stock airbox but it does fit. It is a cheap upgrade too, 20 to 30 bucks depending on where you buy it. Your results may vary depending on your mods but with mine it worked great.
    ktmcrasher is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2012
    cumbria england
    186
    do you have i link for the spacer?
    almost 89% of the people on here call bullchit.. I run them on my bikes.. what it does is move the reeds and carb back for more room for gas and air to mix .. more volume if you run a big carb..before the boost ports...
    Mexico
    9,020
    This kind of stuff always makes me skeptical. I can see how a spacer could add to the bottom end of a 4 stroke, but on a 2 stroke isn’t the hot ticket to reduce the areas that otherwise reduce the point at which a downward moving piston creates enough pressure to seal the reeds and start moving air up through the ports? And if we can agree on that would it also not make sense that the added space would mean that the upward moving piston would have to be a little higher up the bore to have produced enough vacuum to open the reeds due to the increased volume the spacer has created?
    I would never claim to be smart enough to know if what I just typed is 100% true, but I’m pretty sure that a lot of times people mistakenly attribute gains in power to a device when they may have had a jetting, or timing issue that the modification helped mask. i.e. a very richly jetted four stroke engine would likely make power if you simply put an open pipe on it with no other changes where as if you put that same open pipe on an engine that was jetted spot or a little lean with the stock pipe on it would likely fall on its face.
    The only way to know for sure if something works for sure is to dyno test it or run it down the drag strip, but if this spacer puts a smile on your face that’s the main thing
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,246
    i call bs!!! without a doubt!!! there is NO PERFORMANCE GAIN BY MOVING THE CARB 3/8 AWAY..... ZERO ZIP NADA!! its all in your head and a couple of dyno pulls will prove that....
    Arizona
    843
    I don't need a dyno to tell me the engine pulls much harder. I have seven 3 wheelers (not including my quads) and have been doing all kinds of engine and chassis mods for 10 years. When a mod doesn't work I acknowledge it and either remove it or try to improve it. The only thing that changed between my back-to-back rides was the reed spacer. No jetting changes and the temperature was the same give or take a few degrees. When it comes to the theory behind it, I assume it works similar to a boost bottle like the stock Z has or the Banshee. It provides a larger reservoir of air-fuel charge for the engine to draw on. I'll have to look into the theory more but for now I just know it works. I've used them on my Tecate and 250R as well but frankly didn't get the same gains--or is that just my imagination? All I am claiming is that for some reason my Z as it is currently modded really liked it.
    Reed spacers have been around for a long time and they sell them for most two stroke motorcycles and atvs. If they were complete and utter BS they wouldn't have been around for so long. For those that are interested, I got mine through Dennis Kirk:
    https://www.denniskirk.com/moose/tor...prd/181097.sku
    Read the product reviews and you will see that others have reported similar gains.
    OHIO
    2,857
    This may shed some light on it??? It is all rocket sceince to me but here ya go.....quote from Flowtech.... to get technical its not to shoot atomized fuel into the boost port your transfers aid this pushing pulling fuel consuming effect on the down stroke ,the theory behind them(reed spacers) is alot more complex then to just better aim at the boost upper transfer port. larger volume expansion chambered and /or modified machines create more of a push pull effect of pulse waves through your motor this must be equal on intake side for maximum effeciancy reed spacers pull back reed intake which lowers crankcase compression (not static compression) this equals out the natural push pull sonic pulse effect and puts broader powerband hit near the midrange of its rpm,which his wear a 2 stroke makes most of its power ,this is why its more noticable on modified machines with higher rpm (higher exhaust timing)aftermarket exhaust systems and on ported cylinders Can anyone explain that a little easier or tell if it makes sense and report back??? I am always wanting to understand the pingers a little more.....
    Arizona
    843
    Here are a couple of pictures with the spacer installed.
ID:	163441Click image for larger version.
    Thanks for the theoretical input crazy70man. I'm also into theory but haven't delved too deeply into reed spacers. It sounds a little like exhaust theory (especially two stroke pipes) which relies heavily on the manipulation of pressure waves.
    na
    5,702
    The thing is you deleted your factory boost bottle. Plus you have a ton of aftermarket stuff on your engine. So your engine may like it. A stockish set-up probably won't yeild any benefits from it. Theoretically reed spacers add crankcase volume. The Z always has had a small intake vs other machines so possibly when you get into major engine mods on a Z the extra volume may help. Personally I dont run them and dont feel they do anything for my engines.
    Proudly NOT a member of
    "Team on the Teat"
    Oct 2012
    cumbria england
    186
    looks good even if you don't get improvements! can you tell me about that force 3 reed block? where did you get that?
    na
    5,702
    V force reeds have been around for the 2 series for quite some time as the Wr250 application would fit the Z. Later on in 2007 it was discovered a late model Kx125 shared the same bolt pattern intake and V force offered a 3 series for that application.
    Call V force now none as Moto Tasanari and tell them you need a part number as follows....
    V303a with 682m pedals.
    "Team on the Teat"
    Oct 2012
    cumbria england
    186
    cheers for the info mosh
    Terryville,CT
    1,616
    i have one on one bike and not the other. I feel the difference and they are both tri-z's. obviously i am biased, and it could be in my head but that's half the battle right making yourself happy?
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    Quote Originally Posted by christph View Post
    I know nothing of Tri-Z's, I've never even ridden one. I don't know anything about reed spacers either. But I do know about boost bottles, and I know they do absolutely nothing. So your comparison may not be working they way you intended, at least not for me!
    Mexico
    9,020
    I recall once seeing a photo of a rubber insert for a Tri-Z that basically filled and streamlined the cavity of the intake runner and reduced the volume of the tract a lot. I’m sure I saw it on here. Do any of you know about these or recall seeing one, or am I officially losing my mind?
