Results 1 to 11 of 11
Thread: Honda Atc200es Still No Engine Braking!!!!
    Feb 2013
    Adelaide
    127
    Replaced the clutch shoes and absolutely nothing happened I give up...
    Jan 2013
    minnesota
    5,911
    Hello
    I thought i saw post you had regarding this issue recently can you send me a link.
    Apr 2012
    USA
    4,129
    I don't know if the 200es is the same basic setup as a 250es, but there is a one way bearing that commonly goes bad on the 250es's primary clutch. Side effects are no engine brake and the kick starter slips. Of course your pull starter won't be effected by it, but maybe that is what the engine brake problem is? Seems like it shouldn't go bad since it isn't used to start the engine like in the 250es setup.
    Jan 2013
    minnesota
    5,911
    Hello
    If it accelerates fine AND idles in gear without engine stalling then your problem is most likely the one way bearing. See item 14 in link below. Also check item 4 and the inside of clutch hub where the bearing rides for damage.
    http://www.cmsnl.com/honda-atc200es-...7.html#results
    Jan 2013
    minnesota
    5,911
    Hello ps2fixer
    Sorry to repeat your comment I did not see your post. It didn't appear until I send and the page was refreshed.
    Apr 2012
    USA
    4,129
    not a problem, just shows more than 1 person thinking alike lol. Just as an FYI, you can edit your post for small changes like that.
    Feb 2013
    Adelaide
    127
    Are you guys 100% sure? Because I have a spare one and dont want to take apart the motor again for no reason ..
    Jan 2013
    minnesota
    5,911
    hello Aussie
    Would you prefer another answer, sorry but not being there and not being psychic it's the only suggestion I personally have.
    ps2fixer Thanks for the tip however I do not have an edit button it's a mystery to everyone. I would have edited to read I agree with ps2fuxer etc and still posted the clutch picture so he can see if something is missing.
    Thanks
    Feb 2013
    Adelaide
    127
    Ok well I will try it again when I get time.
    Feb 2013
    Adelaide
    127
    Could this be the only possible problem?
    Feb 2013
    Adelaide
    127
    Is this one way bearing behind the shoes?
