This has come up a lot lately, so i will document it quickly here so i don't have to post this over and over anymore... LOL
Here is a picture on this page with a wiring diagram for changing the plug over to the newer style. You can buy the connector from him but it doesn't have the correct latch on it, i have a better source for those, the CDI unit from his is $19.99 but they can be had a lot cheaper as well, or order from him as i have bought a couple of his and they are just as good quality.
http://dratv.com/cdiunatseeap.html
Ok for the connector go here...
http://www.vintageconnections.com/
On the left side click Price List, then on the right scroll down about half way and look for HP6L Latching Set
White Nylon, its the 6 pin connector. Order a set of those and now you have the correct connector.
The CDI is called a 5 Pin CDI, yes there is six positions but only five contacts, the picture at DR ATV explains the wiring just wire the connector as he has it, the one wire is no longer used and so just gets pinned into the open position.
Here is the cheap ones i buy, they have been VERY reliable and durable. No problems.
EDIT: The previous seller's CDI's seem to be having issues now, the ones with the Green connector seem to have become unreliable. The ones i am trying now have a Brown connector, tested one today it works great. So not sure whats going on, bad batch maybe, or they changed somehow. These Brown connector ones are Shindengen brand, name molded into the bottom, and these are the brand i have seen on many Honda products. So for now i am changing my supplier!
http://www.ebay.com/itm/151107921202...84.m1497.l2649
If you have any questions or problems feel free to ask. I have put these cheap CDI units on a few 200ES's including my own i use almost daily. It will work on virtually any ATC model or year that has the square connector or can be changed over to the correct connector. I have put these on 185s, 125M's, and a multitude of 200 models. I think the CDI is going to be a common failure point due to age of the components inside it, electrolytic capacitors don't last that long with the conditions these see, and 20+ years is a good stretch for sure!
