Oem frame and body paint available here
OEM MOTORCYCLE PAINTS
I just recently posted the following info for member kevink and thought it might benefit others searching for the same thing. One of two colors listed below “should” be the original color for 75% of all silver color Kawi frames. After almost 30 years of paint formula changes caused by increasingly stringent EPA regulations, none of the paint available today will exactly match any OEM paint that is more than around 4 years old.
If you own a bike other than one made by the mfg of the fastest production bikes cube for cube in the world then please disregard this post. The paint mfg listed below does not carry any RED paint nor any other color for your bike so please do NOT go looking for any there, they just ran out, it has been discontinued, the part of the plant that made that color recently burned down… Well maybe they might have some.
They make it in different sizes and also spray cans.
This is a kawi frame paint but I think it is slightly brighter than the orig which I think is gentry gray. Both colors available from colorrite.com see bottom of page. I would use this one because it is a little flashier. Both are ultra fine metallic silver as original.
SHOWS REAL FLAME SILVER FRAME COLOR
http://mymotorbikeparts.com/vmchk/Ka...IRING-KIT.html
xxxxx
ALL LINKS SHOW REAL GENTRY GRAY FRAME COLOR, IT SHOULD BE THE ORIGINAL T3 FRAME COLOR
http://www.cyclechaos.com/wiki/File:...ackWheel02.jpg
http://www.cyclechaos.com/wiki/File:...Back_Wheel.jpg
SEE 92 NINJA 600R 5TH BIKE DOWN FROM TOP
http://www.cyclechaos.com/wiki/Kawasaki_ZX600C
xxxx
COLORRITE.COM OEM MOTORCYCLE PAINTS
For support, you can use the form below, e-mail us at support@colorrite.com or call between 9 AM - 8 PM Eastern Time M-F.
* East Coast Sales and Support: 800-358-1882
* West Coast Sales and Support: 800-736-7980
* Canada Sales and Support: 800-461-2324
THIS SHOULD BE IT, GENTRY GRAY
http://colorrite.com/product/kawasak...-gray-1527.cfm
XXXXX
49- n.a. 15- 2167 GD GENTRY GRAY MET. (FRAME)
49- n.a. 15- 2241 KF FLAME SILVER NO. 30 (FRAME)
http://www.japartsnl.com/Eng/Motorverf/kawasaki.php5
http://www.zrxocboard.com/board/show...CODES-REVEALED
//ArrowChat Integreation Code
