Hello all,
Matt here, I've been searching this site for weeks trying to get my bike running right.
Here is what it is doing.
I put the choke on once and pull start it and nothing. Try it without the choke and nothing. I could pull it 20 times and nothing. Roll it down the hill and pop it into 1st and it fires up. At this point I have to
keep on the gas until it is warm. If I don't let off it will run perfectly. Once warm after about 5 minutes I can use the kill switch and it will pull start first time. I went on a 45 mile ride last week and as long as i kept it warm it fired fine.
Here is what I have done so far.
New carb
New air filter
New CDI box
New Ignition coil
New spark plug/ Tried 2 new
New Lightning coil (got the fly wheel off and replaced it.)
Ohm tested the exciter coil and it was fine at 245.
Set the carb at the 2nd notch of the needle like in the manual I have
Turned the air/fuel mixture in all the way and backed it out 2 turns
Set the idle to 1400
Did a Valve adjustment set at TDC .002 with the Rotor aligned and there is no knocking.
No oil leaks
Chain tensioner is set
Clutch is set
Kill switch is clean and works properly
Ohm tested the CDI wires coming out the side of the rotor and the tested fine also the gap was .3 on the rotor.
Broke the pull rope trying to start it so I just fixed it.
I'm at the point where I'm going to give up.
I ordered another Ignition coil off ebay Just to make sure it wasn't the other new one that is bad.
Should get it in a week.
It literally runs perfect when it's warm, any thoughts?
