Results 1 to 6 of 6
Thread: Will an 85 ATC250R motor work in a 88/89 quad?
    BIGKAHUNA is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2002
    220
    Was just wonderin if it will bolt in with no mods. Are the quad motors stronger? What are the differences between the 2?
    May 2002
    Southeastern Wisconsin
    3,658
    The 85 motor is identical to the 86-87 except it has a slightly higher compression ratio.
    '02 Honda 416ex - A seasoned blend of 11 herbs and spices
    '04 Honda Recon - The yard machine and snow plow
    '88 Honda CR250R - Another chapter in my torrid all terrain affair
    dogger is offline At The Back Of The Pack Arm chair racerFirst time rider
    in answer to your question, yes it will. the differnce will come when you mount your motor in you won't be able to make use of your rear engine mount. there are still three other mount's you will use just not the rear. that is all because they canged the swing and the swing arm mount in 88.
    May 2002
    3,658
    They all have those extra holes. 88-89 had them too but didn't use them.
    New Hampshire
    794
    To clarify, the motors are NOT identical. Honda made subtle improvements to the engine throughout its production run. I will not go into details, but I can assure you the Atc engine (85 or newer of course) will bolt right into any Trx250r chassis.
    Clarks Summit PA
    1,236
    yepper... they will bolt right in.. that is why you see the rolling chassis's for sale for the atc 250r.. they steal the motors from the atc's to put in the trx...
    Ride it like you stole it! And never look back! They are too far behind to see!
