Page 5 of 5 FirstFirst ... 3 4 5
Results 61 to 75 of 75
Thread: ATC 250SX Rear Shock Alternatives
  1. #61
    Oct 2011
    Connecticut
    88
    So I now have a choice.....
    A. Purchase a 300EX shock off of our favorite auction site for roughly $50
    or
    B. Purchase a 2001 Raptor Shock for $100. The Raptor shock is a direct Bolt-on to the 300ex and therefore should work on the SX. It has to be a 2001 because that is the only year where they had a remote res on it. My feeling is the raptor shock has 3 adjustment points (preload, compression, and something else) which may be helpful in tuning it for the SX. It may also just end up being too stiff. Also, with all of those parts, it has more potential to fail over time assuming the one I receive is good.
    Thoughts?
  2. #62
    GSUwhiskers's Avatar
    GSUwhiskers is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2014
    Georgia
    168
    I wish I could choose one and you choose the other and we see which works better, but I'm too strapped at the moment for experimentation. I'm really glad you have taken such initiative though. So have you absolutely verified that a 300ex shock will fit a 250SX? I saw you mention having to fab some bushings?
  3. #63
    Oct 2011
    Connecticut
    88
    If you search deep in the bowels of the site, you find some interesting stuff!
    In the last post of this thread, we have proof of someone running a 2001 raptor rear in an SX, but he claims in other threads that it's a little too stiff even at the softest settings. I'm 100% positive that the raptor shock is a direct bolt on to a 300ex and 99% sure that the 300ex will bolt in to the SX too.
    The question now is in what will give the best ride. I do heavy trail riding, usually on rocky logging roads at higher speeds and want soft, but not bottoming out/dangerous soft
    http://www.3wheelerworld.com/showthr...t=Raptor+shock
  4. #64
    May 2014
    Georgia
    168
    So what kind of riding is ideal for a stiff shock?
  5. #65
    Oct 2011
    Connecticut
    88
    More track, whoops, jumping type stuff which I've gotten too old for, although a stiffer setup can absorb some of the rocky terrain at higher speeds though.
  6. #66
    Oct 2011
    Connecticut
    88
    So I spent a little extra for a crispy clean 2008 300ex shock on eBay and it fit great with two spacer washers and some reducer bushings! I won't know how well it works until my first real trail ride, but it looks and feels very promising.
    The original shock was mounted with the adjustment on the bottom and the 300ex shocks seem to be mounted with adjustment on the top, so I mounted it that way. Not sure if it was correct or not, so I'm open to feedback!
  7. #67
    May 2014
    NW Houston (Cypress)
    57
    Quote Originally Posted by dreux13 View Post
    How did it ride? I am looking to do this to my SX as well and will spend the extra cash for a clear newer 300ex shock but am fearful that the ride quality will not be worth it...
  8. #68
    Oct 2011
    Connecticut
    88
    I finally got a chance to ride it with the 300ex shock and it rode great! It was on a light track up at the New England trike fest at Backwoods. While the back end feels stiff to just push down on the grab bar, it soaks up everything when actually riding! Definitely a needed upgrade!
  9. #69
    Apr 2012
    USA
    4,114
    It fit great with two spacer washers and some reducer bushings!
    Were the washers and bushings a standard size, or did you have to machine your own?
    Glad the ride report came back good. The spring looks heavier, and compressed more, but it is progressive. Did you noticed your stock shock was adjusted to the stiffest setting?
  10. #70
    Oct 2011
    Connecticut
    88
    For once, I didn't need to do any machining! I simply bought the 12mm to 10mm reducers found here.
    http://www.dimecitycycles.com/12mm-o...-adapters.html
    The washers were simply spare washers I had in my parts bin.
    The stock shock was on its stiffest setting as well. Between the 200x forks, the 300ex shock, and my pro taper bars, this thing is so nice to ride!
  11. #71
    Apr 2012
    USA
    4,114
    Thanks for the link and info, I'm tossing the idea around, but probably should look into getting new bearings first since it seems the swing arm bearings are pretty shot on my machine.
  12. #72
    Aug 2014
    South Louisiana
    1,915
    Has anyone tried the 300ex shock on an 85 Big Red?
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
  13. #73
    Maine
    464
    I'll have to take a look at one of my sx's i bought a few years ago. It has a red shock on it. It might be a ex shock...
    Current Trikes
    2 1985 Honda 250sx
    1985 Big Red
    2 1983 YTM 200k's. 1 for parts.
    KLT 250 Prairie
    1982 Honda 185 - Waiting to be saved
    1985 125m Parts Machine
    Still on the hunt for a 1986 350x and 250r.
  14. #74
    May 2013
    Medford, MN
    56
    Side by side comparison of a 01 raptor 660 shock and a 250sx shock.
    Sadly the raptor shock doesnt just bolt on. Theres some clearance issues for the top mount
    Sent from my SM-G920P using Tapatalk
  15. #75
    Manheim, PA
    5,742
    use a stock 300ex one. It will be way better
