Results 46 to 59 of 59
Thread: My Honda 200e/s 2 wheeler conversion
  1. #46
    Nov 2013
    Oxford CT, New Haven County
    983
    Quote Originally Posted by cap View Post
    It's been done by atc500x, came out awesome!
    http://www.3wheelerworld.com/showthr...-Fat-Cat-250sx
    wow, that did... he must be some sort of evil genius or something...lol Id love to make my Yammie into one. that would be killer for cruising around in the woods. no more having to judge if your ass end is gonna fit between the two trees up ahead.... lol
  2. #47
    MPDano's Avatar
    MPDano is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2014
    Quote Originally Posted by joefixit0 View Post
    Thanks for the advice, there are no holes in the tank, just a little rusty, I think I will try and give it a good cleaning first, I've heard too many bad stories of the tank liner not adhereing properly...
    Not true in my case. I used the Por15 kit 3 years ago in my 79 Honda Odyssey and it's holding up just as it did the day I coated it. You have to follow the instructions to the T, but it's well worth it. My tank should have been thrown away as it was that rusty inside. It had pinholes everywhere too.
ID:	202265Click image for larger version.
ID:	202275Click image for larger version.
ID:	202274Click image for larger version.
ID:	202276Click image for larger version.
ID:	202266Click image for larger version.
ID:	202267Click image for larger version.
ID:	202268Click image for larger version.
ID:	202269Click image for larger version.
ID:	202270Click image for larger version.
ID:	202271Click image for larger version.
ID:	202272Click image for larger version.
  3. #48
    MPDano's Avatar
    Sep 2014
    Hey wow, thanks for all the comments, I haven't been on here in a while, here's a couple pics of the finished product except for fork boots and side panels...if any one has a really crappy pair of 200e es or m rear fenders that I can cut the side panel part out of let me know. I need basically the triangle and the plastic along the underside of the seat only. I'd never cut up a nice fender! I ended up lengthening the front forks about 3 inches to get the front up, handles way better now. If you check out the pics, I just added the bottom clamp part from a bent pair of forks that I had sitting around the shop. The 2 wheeler has plenty of power in high range, I barely have used low at all. One other mod I think I may do is to narrow the footpegs down a bit, because this thing is way wide, and if you have to put a foot down in a hurry, you'd be likely to get it sucked under!
    Genius work man. I too would like to tackle this on. Thanks for the progress pics.
    Leo
  4. #49
    cap's Avatar
    cap is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2014
    Nevada
    163
    I'm still riding my Joefixit style BigWheel.
    Tired of running over my legs I finally cut down the pegs.
  5. #50
    cap's Avatar
    Jan 2014
    Nevada
    163
    Anyone else build one of these cool bikes yet?
    Made some bar risers today also, I'm 6'1" so now it's even more comfy!
    Old risers for spacers.
  6. #51
    Dec 2013
    Very nice job.
  7. #52
    May 2015
    San Diego, CA
    1,743
    I want one now. It appears to be fairly straight forward. You both did an outstanding job.....really inspirational. Now I just need a yamaha swing arm and an old big red pile.
  8. #53
    Apr 2012
    Georgetown,Ca
    101
    Here it is after 3 years and quite a few miles, still going strong! Additions include front rack with custom headlight lift bracket, aluminum side covers and 10 gauge steel skid plate.
  9. #54
    Oct 2017
    Utah
    You have mentioned a couple of times that you extended the front forks. How did you do that?
  10. #55
    Nov 2013
    983
    that thing is so badd a**.... good job on the build! I bet its fun to ride!
  11. #56
    Nov 2017
    Michigan USA
    13
    Looks awesome !
  12. #57
    Feb 2018
    Indiana
    23
    Quote Originally Posted by my1423 View Post
    Not bad should be really fun.
    Few things to help out from things I have learned from friends builds and mine.
    The jack shaft slack will drive you nuts!
    Since you are using an 83 big red you have to be really careful on the chain to prevent breaking the case or wearing it.
    The bw200 inner sprockets are 530 not 520 chain. Not sure if they make a 530 front for the 83 or if the 530 chain will clear the case inside.
    Might want to check. You can always cut the inner jack shaft sprocket down to a 520 but trust me, try to keep 530 on it.
    That chain is really under stress on speed changes and with the case being so closed in the risk is much more.
    The 200m my bud has broke many a front chain.
    My bw200 has not broken the front on me. Slack on it really annoys me riding it.
    Noisy and jerky!
    Try to get the angle of the swing arm pivot, front sprocket, and jack shaft all in a straight row.
    tack the bits in place and sit on the rear and see your alignment with the shocks compressed.
    The chain will always rub the guide on the swing arm but you can move the shock mounts around or the pivot to make it not rub most of the time.
    Saw one recently on a ride. Really neat way they did it up.
    They added a little plate to move the pivot back 3 inches and 3 beefy chain rollers right in front of the pivot as chain guides.
    One in the middle of the chain, one above, one below.
    This way the chain will never rub the swing arm and will stay tight in a line.
    As the arm drops the lower and center wheel hold the chain in place for the shaft.
    The front end will need work.
    Rode one that the guy cut the neck and pushed the front end out a few degrees. Guessing 5 or so.
    The bike was really twitchy and hard to control in rough stuff with the stock 3 wheeler nearly vertical rake.
    Flipping the forks around helped.
    Adding length to the forks really helps as well.
    The one I just saw had the kawasaki front end on it.
    They cut and extended it to make level the bike for the front is already low and the frame rake made it lower.
    Like this front end but with 3 inches added to it.
    http://www.3wheelerworld.com/oldsite...0bklt200cB.jpg
    my1423,
    I am working on a conversion myself and I am curious about the lengthening of the front forks. How do you go about lengthening the font forks?
    Thanks,
    Thor34
  13. #58
    Apr 2012
    Georgetown,Ca
    101
    I cut the clamping part of the forks off of a pair of bent forks that I had and welded them to the bottom of the forks, gaining approx 2" in height.Click image for larger version.
  14. #59
    Feb 2018
    Indiana
    23
    Ah, Ok I see it. Thanks for the follow up. Your bike is awesome, I saw your youtube video before i found you on the forum. Definitely and inspiration for my build.
