Results 1 to 15 of 23
Thread: 200s stalls when hot
    PAPA250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    greentown PA
    389
    Having an issue with my 84 200s stalling once its hot it runs great other wize .
    Recently put a new rickystator in it and the carb was redone with OEM parts on unrelated issues so its not those
    It starts right back up a minuet or two after it stalls i am pretty stumped . Can these things vapor lock ?
    PS i tried to run it with out gas cap still does it
    84 200s almost done
    84 atc 70 project
    mike84bigred's Avatar
    mike84bigred is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2006
    North Tonawanda, NY
    343
    Plug fouling? Although it does start back up again, but just a suggestion.
    84'200s (Dad bought new in 84, long gone)
    84'YTM200 (sold 02)
    85'KLT160 (sold 05)
    84' Big Red (Cobra exhaust,good shape) sold in 08
    84' Big Red (Parts Bike, runs good though)sold in 08
    85' 250SX (New plastic, Clark Plastic Gas Tank, Web Cam Camshaft, Cobra Exhaust, Moose Jet Kit, etc..) sold in 2010 and highly regret!!!
    04 Polaris Sportsman (Swapped 400 motor with a 500, Polaris wheels w/Kendra Bearclaws, Moose Fender Flares, Brushguard, Warn Winch)
    84 200s (Needs work!)
    Southern MN
    1,875
    I have seen this problem before when the ignition coil (to the spark plug) was going bad. You can test it yourself, just have a look at the manual, you just need a volt/ohm meter and check the coil OHMs per manual. You can also test the ohms going to the stator coil, just to be sure that one is not faulty.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Feb 2009
    greentown PA
    389
    Hummm thanks I will check the coil when its hot and see what it reads .
    84 200s almost done
    84 atc 70 project
    Oct 2006
    North Tonawanda, NY
    343
    I think you can get a new coil for $10 for these things. I would buy a new one anyway.
    84'YTM200 (sold 02)
    85'KLT160 (sold 05)
    Grande Prairie, Alberta, Canada
    96
    One thing to watch for.... an ignition coil or a stator may test out as perfectly fine when cold, but will fail when hot. Try to get the bike to warm up until it stalls, THEN test the components. CDI boxes can do this as well, I've pulled a few apart and found the solder that connects the pins to the board have melted. Unfortunatly honda CDI's are epoxy potted and can't be fixed.
    Feb 2009
    greentown PA
    389
    Thanks thats good information . I will check it out tuesday Hot and cold lol
    84 200s almost done
    84 atc 70 project
    Mexico
    9,014
    If not electronics you may have some floaters in your float bowl that are plugging up your jets and then dropping back down into the bowl after it stalls.
    Mar 2007
    Texas
    5,045
    i think you could have a fueling issue. when was the last time you took the carb appart and cleaned it up perfectly clean? if it has been a while, may try that if coil tests ok. when i first got my 200x it did the same thing. i ended yup hacing to over adjsut the idle screw, set the needle to 1 from the top and put in a bigger jet. no more problems and runs like a scalded cat!
    ________________
    https://www.mikesatvfix.com
    Feb 2009
    greentown PA
    389
    The carb was totally rebuilt with oem parts . And it was doing it before i rebuilt the carb
    84 200s almost done
    84 atc 70 project
    Feb 2009
    greentown PA
    389
    After testing the coil it was good . Turned out to be the new stator from ricky stator the lead where it solders on was loose and melted when it warmed up
    I wish they still sold oem source coils all of the aftermarket ones are crap it seems didnt even last 2 months
    84 200s almost done
    84 atc 70 project
    MN
    3,263
    I had that happen on a ricky stator as well... How i fixed it was to get a crimp terminal, such as a ring terminal, cut the ring portion off so you just have the back sleeve part of it that crimps onto the wire then put that over the wire that goes to the wire from the coil, crimp em together and then solder the buggers. The crimp will add some mechanical strength to the solder joint. That one about drove me to drinking when the owner rolled it off the trailer swearing at it. I finally tore it all apart and found the same thing you did.
    My guess, they used regular old rosin core solder, they should have used higher temp silver solder or at least high temp tin alloy to prevent melting.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Feb 2009
    greentown PA
    389
    Thanks but I am not sure this ones fixable . Plastic melted and the piece where you solder to fell off as well
    84 200s almost done
    84 atc 70 project
    NEPA
    7,049
    Sounds like nothings changed out there.. Why do companies sell crap?
    MN
    3,263
    Ahh, it was too far gone then. I got lucky and fixed it, but i haven't talk to the guy in a while, wonder if it kept working... LOL
