Thread: 1985 250r leaking case oil
    Auto_Demon's Avatar
    Auto_Demon is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Stonewall, Manitoba
    290
    k so i found this today and i dont know how to fix it.Click image for larger version.
ID:	174568 sorry the photo is sideways.k so that plug can spin freely and i just noticed that it leaks oil from there. it looks like there is supposed a cap welded on there but its gone, do i have to get a whole new case cover or is it possible to fix it?
    1985 Honda ATC 310R
    "Man your 4 wheeler must be fast, cuz you were haulin' ass, when I passed you on 3 wheels"
    Slidell, LA
    4,738
    You need a new case. Looks like a shadetree fix for a hole that was punched through the case.
    Auto_Demon's Avatar
    Stonewall, Manitoba
    290
    i found a major issue Click image for larger version.
ID:	174596 Click image for larger version.
ID:	174597. so the bolt thats holding a gear on was completely loose and was grinding through the case making that hole...
    1985 Honda ATC 310R
    Jun 2004
    Oregon
    1,783
    Ouch......
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    MN
    3,263
    That case could be fixed by a good welding shop that is setup to TIG aluminum. But it amazes me that it was tossing that much metal shavings around inside and it hasn't killed it! I would go through and inspect everything, clean it all out good. There must be a LOT of shavings in there somewhere.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
