Page 4 of 12 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 46 to 60 of 166
Thread: parts that inter change with TRI-Z 250
  1. #46
    Watertown, New York 13601
    3,382
    Quote Originally Posted by Dammit!
    Apparently there's an even cheaper option. LonesomeTri-Z got them for 12 bucks each brand new. Supposedly off a Suzuki. Identical to the Z headlight in every way.
    It's progress though! 38 bucks is still a lot better than 65.
    I wish he would fill us in. I never heard that.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
  2. #47
    Phoenix, AZ.
    6,719
    He doesn't remember what bike it went to. I'm going to make a trip to a local suzuki dealer Monday and see if they can match it up.
  3. #48
    3,382
    good luck. I can't see these headlight's selling for $12.
    2006 YFZ 450
  4. #49
    Jul 2003
    Ontario Canada
    813
    the shift shafts are not the same unfourtnetly
    the YZ is about 1/2 inch shorter, just enough so you cant get the shifter on
    Curtis
    Currently Trikeless- but I have a LT250R
  5. #50
    Dexter, MO
    34
    here you go dammit
    not the best pic but for $30 its yours
  6. #51
    Aug 2004
    Ab Canada
    4,368
    just to let you know- the 85 Yz and the tri-z heads and head gaskets are not even remotely the same, the YZ use's o-rings, to run the YZ piston you need the whole cylinder not just a sleave in the Tri-z jug, the intake on the YZ is MUCH bigger and lower on the bore.
    1985 Tri-Z-
  7. #52
    May 2005
    Hobart, Oklahoma
    570
    I just put the complete hub/axle and front tire off of an 85 200x on my Z , and I also put 300ex rear hubs on the back (axle was worn, 300ex hubs were new and fit tight). The front brakes take some working, but they will go .
  8. #53
    Phoenix, AZ.
    6,719
    Can you use a 250R front wheel on a Z?
  9. #54
    diggerzmound is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2004
    Nebraska
    187
    Quote Originally Posted by My trike Sucks
    Wrong, the head gaskets are the same, the YZ didn't go to O-rings until 86.
    My Ride - 2001 Raptor, HotRods 720 Stroker.
    94' Banshee- Bing Bing Bing
    85 Tri-Z, 6 Speed, Power Valved, Boyesen Reeds, DG Pipe.
    Kids - Lil' Yamahas
    Summer rides - 1100 Wave Raider, JS550, 06' V-Max
    Winter toy - 95' V-max4
  10. #55
    May 2002
    Southeastern Wisconsin
    3,658
    I've put a tri-z wheel on a 250r so I know they swap but I don't know about the brake, I don't think that will work.
  11. #56
    3,382
    A memeber here named Jeb has done this switch on his Z. I would ask him for more details.
    2006 YFZ 450
  12. #57
    na
    5,702
    honda 300 ex 400ex and 250x hubs bolt up in the rear for more width too.
    Proudly NOT a member of
    "Team on the Teat"
  13. #58
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by diggerzmound
    Ah my bad, i have an 86 set up..
    1985 Tri-Z-
  14. #59
    Nov 2004
    Beaverton, Oregon
    75
    Howdy....
    The YZ 490 swap was mentioned a couple of times in this thread.....
    What year 490?
    Air cooled, or water cooled? Was there ever a water-cooled YZ 490? Sorry, but while I have spent a ton of time on lots of different bikes, my 490-nese is sorely lacking...
    What about the rear-kicker design of the 490?
    A 490 swap is not in the cards right now, but it would be something pretty darn interesting to do later on, as I have access to a couple of different YZ/IT 490's...
    PS: Does the Banshee rear brake rotor work on the Tri-Z? There are some interesting wave rotors for the Banshee out there....
  15. #60
    May 2002
    3,658
    Quote Originally Posted by moshman355
    Actually they don't unless you have wear on at least one of the parts. Fresh you could barley them on.
