Thread: 1000cc 2 stroke triple sled- redoing pipes, need paint advice
    Sep 2011
    New Castle, PA
    1,132
    This isnt actually my sled, it a friends. The story goes that he seized a piston and cracked a wall, so he had all cylinders and pistons (overbore & nikasil plated) redone and ported. While its been apart, he wants to have his chambers blasted and painted. I did the blasting today, and he gave me some high temp paint (space age 2000 degree aluminum) to do them up with, is this good to use? I trust him, but you guys know more than I do
    Thanks
    Gone:
    Aug 2004
    Ab Canada
    4,368
    Get them High temp Powder coated if you want it to last...i have never seen any paint last on sled pipes..too much hot/cold/snow hitting them all the time.
    1985 Tri-Z-
    Blossvale NY
    4,542
    Quote Originally Posted by MTS View Post
    Agreed.. either that or ceramic coat
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Mexico
    8,956
    ceramic coat
    That stuff is the final word for coating pipes.
    North Dakota
    1,643
    Man Sled pipes are a complete pain to keep looking good due to all the moisture they encounter. Ceramic is the best bet in keeping them look halfway decent. I really just gave up and have been leaving them with some surface rust.
