Results 16 to 30 of 75
Thread: PROJECT peewee
    Apr 2007
    Quote Originally Posted by JasonB View Post
    looking good man! anxious to see your pipe set up next. Hope you bring this out to Trikefest 2014 if you have time to make it
    Thanks bro, i was looking at some sv80 sno scooter cylinders today to see if its a possible bolt on part but not sure, i ordered a base gasket and Ill know when it gets here, the port layout looks a bit more aggressive and they make vf3 reeds for them, if not tho ill go with porting this cylinder and boyessen reeds as I planned, i dont think ill be able to run a down pipe either, too damn low to the ground so up pipe it is.
    Airfoolers RULE!!!
    Apr 2007
    New peg mounts installed, think im going to buy some of those cleated ebay pegs to weld to these bad boys..
ID:	183488Click image for larger version.
    Airfoolers RULE!!!
    Apr 2007
    heres with the new bars i found in the metal dumpster at work, they are from a newer honda 4x4, the grips are like new I just welded a cross bar in from an old tv stand. Does anybody know where I can get a longer brake cable that will work on this thing???
ID:	183689Click image for larger version.
ID:	183690Click image for larger version.
    Airfoolers RULE!!!
    tblumer's Avatar
    tblumer is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2009
    Liverpool NY
    225
    Motion Pro can make you one. I had them make longer brake and clutch cables when I put dirt bike bars on my old 600 Ninja stunt piece.
    84 ATC 70 w/88 (for the kids)
    85 Yamaha YTM200 (Protek suspension / Tecate forks)
    74 Joker frame ATC 90 w/ 110 cdi
    71 Honda Z50AK1 Mini Trail w/117cc stroker
    CRF50 stunter w/117cc stroker
    08 Yamaha WR250X
    My feedback:
    http://www.3wheelerworld.com/showthr...89#post1080789
    Apr 2007
    ya you go putting together some TPC handlebars and you gotta have a special cable now HAHAHA!!!
    Airfoolers RULE!!!
    Apr 2007
    thanks to captainweezy I got my aluminum front rim last night and installed it today now i got alloys all around 3 dif sizes and 3 different tires lol
ID:	184629Click image for larger version.
ID:	184630Click image for larger version.
    Airfoolers RULE!!!
    Nov 2007
    ulysses pa
    1,231
    this is looking great! when i do my mod 70's i like to use tall pit bike bars and i have had good luck with rerouting the stock cable. sometimes i have to bring it up behind the bars but it seems to work fine.
    Apr 2007
    Thanks bro I'm pretty happy with how it's coming along.I'll try what you said with the cable once get a new perch and lever.
    Airfoolers RULE!!!
    C.J is offline Just Too Addicted Arm chair racerJust too addicted
    Central, Louisiana
    639
    Any updates yet dude?
    too many bikes to count. too little time on hand.
    Apr 2007
    I got one small update. I got the pegs welded into the new brackets today. Didn't have time to Finnish up the shifter though but once I'm done there I'm just waiting for my tax return money so the motor can go out for porting and headwork.Click image for larger version.
    Airfoolers RULE!!!
    Apr 2007
    My slick new custom shifter I made..
ID:	185960Click image for larger version.
ID:	185961Click image for larger version.
ID:	185963Click image for larger version.
ID:	185965Click image for larger version.
ID:	185967Click image for larger version.
ID:	185969Click image for larger version.
ID:	185971Click image for larger version.
    Airfoolers RULE!!!
    HondaRidr's Avatar
    Salt Lake
    331
    This is a way cool project
    Apr 2007
    Thanks bro
    Airfoolers RULE!!!
    Nov 2007
    ulysses pa
    1,231
    lookin good!
  15. #30
    Have you made any more progress on the pipe ??
