Results 1 to 15 of 30
Thread: YTM 200 backfiring in carb
    Nov 2013
    SE AL
    38
    What would be causing this? It stumbles when holding the throttle steady and it appears to be backfiring in the carb. Any ideas? Looking to possibly just purchase a new one and was wondering which was best, upgrade or stock? Sorry for all of the questions, im learning lol
    Nov 2013
    Benson, AZ
    147
    There's only 1 thing I'm aware of that can allow backfiring to occur - intake valve is open or poorly sealed, allowing the combustion gases an additional escape path. So check the timing first I'd think, then maybe the valve adjustment - they may be too tight. As a last resort, may need a valve job if the intake valve isn't sealing.
    glendive, montana
    1,822
    are you positive that it is backfiring, or might it be flooding out, also what type of fuel are you running? Have you checked the main needle in the throttle body for any wear or warpage? There are a lot of different things that can give symptoms of backfiring, I do recommend checking the valves and timing, but am giving you some other options as well.
    emmie357's Avatar
    emmie357 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2013
    Upstate NY
    214
    I had a lawn tractor that did this. Timing was off. In my case the flywheel key has sheared and the flywheel slipped out of place.
    If it's not the timing then likely an intake valve not closing fully.
    Nov 2013
    SE AL
    38
    Ok well I can see the carb "kicking back" some when it does it and like a puff of air when it stalls. Will I have to pull the motor out to check the timing and intake valve or can it be done with it in the trike still? Ive worked on trucks a bit but am new to ATVs. Could I run some sea foam or something similar to maybe get it to unstick the valve?
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by Bucksmith02 View Post
    yes, do a compression test twice then adjust the valves and do 2 more compression tests.
    if the valve is sticking you midst remove head to repair it.
    heres a manual. it takes up to 5 minutes to download.
    http://www.oscarmayer.net/atc/manual...vicemanual.pdf
    Nov 2013
    SE AL
    38
    Ok thanks, man you are awesome. I needed that.
    Nov 2013
    SE AL
    38
    Funny thing is it will idle smooth for a couple of seconds and then it will start acting up and shut off unless I give it throttle input. Really wishing it was something simple but in my case it hardly ever is.
    Jan 2013
    minnesota
    5,911
    check the spark
    start it up
    wait until it dies
    check spark again, if it is noticeably weaker it is electrical.
    if spark looks good check float level. too high it is flooding, too low it is lean.
    Jan 2013
    minnesota
    5,911
    drain float bowl into clear glass look for debris. if gas is old like a yesasr or more it will not burn well. if gas color is apple juice color or darker it is either old or discolored from rust in tank.
    Nov 2013
    SE AL
    38
    It fires right up almost every time. So just do a visual check before starting, then once it dies, do it again? Ok will do
    Nov 2013
    SE AL
    38
    Ok I still haven't fixed this issue yet(time) but I did take it out and ride it for a good while the other day. I noticed I had some fuel dripping from the air box. What does this mean?
    glendive, montana
    1,822
    and muthey might be the winner!!!! you are flooding out, which more than likely is causing your backfire issue. time to open the carb and check your float, float needle, and float needle valve, along with the o-ring that goes on the float needle valve.
    Nov 2013
    SE AL
    38
    Good I hope that is it. Much easier than tearing into the engine. Thanks guys for your help so far
    Dec 2013
    Perkasie, PA
    38
    Are there Carb rebuild kits available for the Yamaha 3 wheelers? I have a 225 DRS and would like to clean and rebuild the carb.
