Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: In DESPARATE Need of an Old Vintage Durablue Anti-Fade for a Tecate
    May 2011
    eden,ny
    3,482
    After 2 years of periodic calls and emails to durablue with no results I finally got ahold of someone there that had a clue. I asked for tech support and was connected with "Tom" after a brief conversation describing what I needed and the diameter of the axle, he took my number and said he would call back after talking to engineering. Much to my surprise he called back about an hour later with a part number for me 20-1636 for the second gen. posi lock for an eliminator axle. Im not sure where your at with having these made but it might be worth a shot to talk with the same person I did.
    Plattsburgh, NY
    2,311
    He gave u a part number for a different one that will work ??
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    Plattsburgh, NY
    2,311
    So I should have, in-hand, a new stainless steel anti-fade but for vintage durablue axles for the first gen tecates!
    I will post pics as soon as I have one. Let me know if u r interested. I will of course be fitting onto my build to make sure all is good. This is a big part finally happening. It has been stopping my build for quite awhile now.
    The only other thing is the large snap ring. Does anyone know where to get those? I must be able to contact durablue for those. Gotta be the same or close enough on another model.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    Nov 2002
    Chezzetcook Nova Scotia
    1,836
    My "Finish Line" Axle has a big nut with a small hole drilled to have wire wraped to keep from comming loose. But mine too is siezed in there.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Nov 2002
    1,836
    Here is my topic on this. lol I spelt axle wrong.
    http://www.3wheelerworld.com/showthr...+extended+axel
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    May 2011
    eden,ny
    3,482
    Quote Originally Posted by Tecate250 View Post
    your "finishlne" is a durablue. I had the same issue with mine being seized. Heat didn't help, I cut into it with a cut off wheel on the top and bottom and split it with an air .
    Nov 2002
    1,836
    I was told it was a finish line. Are durablues better?
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
