Report him to ebay and do it right the second time
Gone:
Shouldnt be a problem removing that choke plunger. Drill a tiny hole in it, a slightly bigger torx bit into it, and use an impact gun and get it to spin and break free.
1985 Honda 250r x2
1986 Honda 250r
1986 Honda 250sx
1985 Honda 250sx x2
1985 Honda 350x x2
1986 Honda 350x
1984 Honda 125m x4
1984 Honda atc 70
Yamaha tri zinger
Yamaha 4 zinger
Brap braaaap
I dropped the ball on reporting him to eBay. I was half asleep when I opened it and looked at it. Left him feedback right away. Didn't see the flaws until the next day.
As for ing a torx bit into it. LOL. That sounds sketchy as hell! I may mess with it. I'm just going to wait til I can afford one of FlyingW's carbs.
Edit - No offense intended, Jason. For me to attempt the torx bit trick would be sketchy. I would most likely damage the carb even more. I have no doubt your method is proven. I just don't want to be the guy to destroy it completely. It's better left to someone with experience.
86 Honda ATC 200X Frankentrike (Project)
80 Honda CB650C Conversion (Project)
3WW Feeback Thread For DasUberKraut
Retired Machines - 02 Honda TRX 300EX, 85 Honda ATC 250SX, 84 Honda ATC 200X Astro Kit, 85 Honda ATC 70, 85 Honda ATC 200 Auto-X, 83 Honda ATC 200E Big Red, 84 Honda ATC 125M (X2), 82 Honda ATC200, 81 Honda ATC 185S, 81 Honda XR250R
My rides (click to view)
6/84 250sx(Original owner)
7/84 250sx
Click here to view my finished SX project thread
Click here to view my feedback thread
I got it covered!!!!!!
I just want to say. I'm truly feeling the love and brotherhood our community has to offer. You simply cannot find the amount of generosity or basic human compassion and kindness anywhere else. I hope to make it to TF to meet all of you truly amazing people and shake your hands.
I've searched a bit and can't find an answer...
Will 200X fork tubes fit the 250SX triples? I got my 200X front end tonight. If I don't have to tear into the triples yet, I'd like to wait til I can afford some All Balls for it.
Not sure, but i did just put a 200x front end on my sx last summer. Be aware you will need to grind off a bunch of the sx steering stop, then add a steering stop to the front of the neck for the sx tripples. If nobody chimes in soon i can run out to the garage and measure the tubes on both forks.
86 250sx - old reliable
another 82 110
-gone but not forgotten-
82? 110 - why did i sell it??
84 225dx - meh, it was a pile
MRSOUND informed me if I leave the SX triples on I'd require spacers on the axle to use the 200X hub. I'm going to just do the conversion with the loose ball bearings for now and get some All Balls after the rest of the machine is squared away. I wanted to use the SX headlight too. So I may try to modify the SX bracket.
I was able to use the sx headlight on mine, it fit a little funky but not that noticeable once it's on. I also used the sx fender, but there's only 2 screws holding it on.
another 82 110
Wow!!! FlyingW!!! Your work is absolutely amazing!!! You made my week, good sir!
Waiting on the choke cable and plunger. I have to hook the wiring back up and rig a fuel supply. Then I can see if this thing actually runs. I did see a few oil puddles under it now that it's been sitting on the lift. One on each side of the engine and one under the differential. I hope it's just gaskets. If he sold me a cracked motor. I'll be upset with myself for not looking it over closely. I'm having a hell-of-a hard time finding SX rubbers for the headlight and seat.
Wisconsinite. Can you share some pics of your conversion and the SX light on it?
Actually... I can't be mad. It's still a Honda.
Doug, headlight rubbers (?) ,,, you referring to the 2 straps that hold it in place ?
Item number 14 > http://www.bikebandit.com/houseofmot.../m1913#sch3032 ?
These things ? >
I'm glad you are happy with it. let me know how it runs.
#'s 11, 16, and 17. My straps are perfect!
Funny thing. I didn't think to check Bike Bandit. I seem to forget about them. I use a couple others for the most part but even then I hate that they overcharge for shipping so I tend not to even check those sites.
Well shoot,,, thought the Mrs. could be of some help there.
Yes, often the smallest of things needed turn out to be the hardest items to get ahold of.
