I see some rub marks on the front fender from the head nut in your pics. Common problem on these is the frames bend at the neck. Easy fix; and you might want to repair the steering tab stop while the tank is off. Its probably bent up causing the forks to hit the tank. Your throttle cable needs to be routed kind of the same as your brake cable but on the other side of the frame. These are minor issues, great buy your daughter will love it. I bet you will too!
