Thread: Recoil plate gasket?
    Feb 2014
    Federal Way, WA
    23
    I did a search, but can't find a solution. I pulled off the recoil starter case on my '83 ATC 200 and it has a metal plate gasket that has deteriorated rubber on both sides of this gasket. Anyone replace this gasket? I see some on eBay, but they look like they are just a rubber gasket and mine is as I mentioned, rubber coated on both sides of the metal gasket. Anyone replaced this part with just the rubber gasket?
    I'm not sure how to continue on this.
    Thanks in advance for any help.
    Dec 2012
    812
    Hey Damon...could you post up a pic? Not sure exactly which gasket you're talking about.
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    Jan 2013
    minnesota
    5,911
    yours is orig and no longer avail. only the rubber or paper repos are.
    Orig p/n 28482-958-013
    Here’s a replacement.
    http://www.ebay.com/itm/HONDA-80-83-...r#ht_355wt_930
    Same as a 185 but there are 2 other seals in there also. See parts fiche below.
    http://www.cmsnl.com/honda-atc185s-1...1.html#results
    6,798
    If your not using the compression release anymore just buy the early version of the thick paper gasket and do away with the metal one . here is one CHEAP !
    http://www.ebay.com/itm/HONDA-80-83-...ab4be8&vxp=mtr
    Feb 2014
    Federal Way, WA
    23
    Man, you guys are good! How do you know this stuff? Haha Shortline10, I had that already on my watch list, but I just didn't know if this was the solution! I thank you all for the help!!!
