Bump start it
Bump start it
Appearing since '07
Looking for a place to happen...
Making stops, along the way
85 Tri-z Basket Case
That's an idea. What are you guys using for exhaust? Looks like most on ebay don't come with exhaust.
pit bike exhaust with a little heat to get your bends works perfect.
So I just searched pit bike exhaust on eBay, is this what you are talking about? If so seems reasonable.
http://www.ebay.com/itm/Big-Bore-Muf...144730&vxp=mtr
I used something like that on my TREX. Took a little heat and a little bending. I should have bent it in closer to the frame - I still melted the plastic a little:
There's a good discussion on Glamis Dunes about pipes:
http://www.glamisdunes.com/invision/...302469&hl=pipe
I'm starting to think this project is pretty straight forward and might not be too much work. Thanks for all the input. I got to go check on the frame make sure it's still in the condition I remember it and if so I'm going to start ordering parts.
I did the 110 lifan with e start swap and had it pretty much wrapped up by the end of a weekend. Had to trim fender, had a custom throttle cable made, build battery box, heat and bend pegs a little, and a few more mods. Most could not tell it had a bigger engine. Hill climbing machine! Well worth the work!
I used a spacer I think 3/8 to lower my foot pegs to clear the clutch cover
84 ATC 70 w/88 (for the kids)
85 Yamaha YTM200 (Protek suspension / Tecate forks)
74 Joker frame ATC 90 w/ 110 cdi
71 Honda Z50AK1 Mini Trail w/117cc stroker
CRF50 stunter w/117cc stroker
08 Yamaha WR250X
My feedback:
http://www.3wheelerworld.com/showthr...89#post1080789
