Found this piston for tecate big bore not sure if its for 3 or 4 Wiseco 73.95 mm has 8005 stamped and 3551J on piston. original box
not available. will try post pics soon. problem is its taller then stock piston from the pin up. May use a spacer plate ?
also it does have an oval hole on intake side unlike the jet ski piston.
