Results 1 to 12 of 12
Thread: Wont start on its own but will run if bump started..
    BiGDawG's Avatar
    BiGDawG is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Millington, Michigan, United States
    384
    any idea why? it's a 82 or 83 Kawasaki KLT 250, if bump started it will run and idle on it's own but for some reason it won't start with the starter? carb has been cleaned and i'm out of ideas why sucks cause this has no backup starter
    82 250r's Avatar
    82 250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    Utah
    278
    Sounds like weak spark or low compression.
    Install a new plug and see if that fixes it.
    Scootertrash's Avatar
    In the sticks
    4,628
    Does the starter turn over and it doesn't start or the starter doesn't work period?
    Nov 2004
    Waterloo IL
    2,701
    Valves may be adjusted too tight.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Oct 2008
    Reedsport Oregon
    856
    its the valves, there just tight, had the same problem
    BiGDawG's Avatar
    384
    starter works fine i'll try the spark plug first if that don't work how do i check the valves? never done that before
    Oct 2008
    Reedsport Oregon
    856
    you need a feeler guage from napa and if you dont know how grab a clymer manual or a hanes, its got to be done on a regular basis on any 4 stroke. i bet you loosen the up to correct setting she starts right up.
    BiGDawG's Avatar
    384
    alright i'll look into it and i did check the spark plug and its all black pretty bad
    lokisbuddy's Avatar
    lokisbuddy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    michigan, oscoda
    429
    check the valves just for good measure also check the compression. low compression will cause the same symptom.
    200x build
    My Feedback
    The world is broken up into two very different groups of people: there are those who like me, and those who can go to hell
    BiGDawG's Avatar
    384
    well for some reason it gets gas to the carb but not the spark plug? found it dry after trying to start it for a good 10 mins
    Nov 2004
    Waterloo IL
    2,701
    Did you adjust the valves yet?
    Oct 2008
    Reedsport Oregon
    856
    the valves are too tight, your not getting fuel, that or your compression is low if you have spark
