SEND ME PM HERE - CLICK HERE
Dirtbikes:
1988 Yamaha DT
Are they both Pro vectors, or is one the P/V 701? The P/V came after production runs if I remember right. May have changed a bit, as you can see, taller, a little more balloon shaped
Gone:
NEVER gets old looking at your stuff bud !!
So clean....
'86 ATC 250R, Build Thread http://www.3wheelerworld.com/showthr...highlight=250r
'86 "Factory Tri racing" Tri-Z http://www.3wheelerworld.com/showthr...b-Top-Tank-ect
Pile of Tecate Parts
My Feedback Thread: http://www.3wheelerworld.com/showthr...edback-for-bkm
Darius that 350X and 250R look brand new! are they restos or original factory bikes? To clear up some confusion, "rg97", I have learned here on the forums that in early production runs of the "1986" 250R/350X/200X came with spelled out PRO VECTORS but later production runs actually came factory P/V 's. Yes OHTSU P/V tires were on late 1986 models and the 1987 200X/ 250SX followed with the OHTSU P/V also.
Dirtbikes:
1988 Yamaha DT
You have some nice bikes there Darius!. I spent hours last night sanding the fenders on my 350X. They were actually in good shape, just had a few deep scratches so I started off with 300 grit wet sandpaper and worked my way up to 2500.
I'm waiting for the new decal set to come in, then I'll finish it up by compounding the fenders, then use a nice clear coat wax that I have from Zaino Bros.
Trikes Currently Owned
~1985 Honda Big Red 250ES ATC
~1986 Honda 250SX ATC
Interesting...send me a pic of that wax bottle. I'd be curious to know about it and if it works well.
Dirtbikes:
1988 Yamaha DT
Dirtbikes:
1988 Yamaha DT
Basically, I'm going to use the Z-14 Plastic Cleaner/Polish first. If I'm happy with the results then I'll just use the spray on sealer directly after applying Z-14. If not, I'll take an additional step to use the Zaino (All in one) product (after applying Z-14 Plastic Cleaner), then apply the spray on sealer.
But since I'm a stickler, I'd probably use all three in tandem, but it's probably not necessary.
Dirtbikes:
1988 Yamaha DT
