Results 1 to 15 of 20
Thread: My Red Tecate Project
    Jun 2009
    Leander TX
    2,217
    Last July, I picked up this red Tecate on the cheap.
    http://www.3wheelerworld.com/showthr...94#post1240194
    Since then, I sold both my green ones and the parts Tecate is dwindling away so this is, technically, my only runner.
    I decided, after the spring ride in OK, I'd like to have a T3 to ride at Rampage so the thrash is on!
    This trike ran and I rode it when I bought it but it needed, primarily:
    - front brakes top to bottom
    - replacement fork tubes & fork rebuild (no damping at all)
    - swingarm bushings
    - rebuilt or replacement shock (no damping at all)
    - chain and sprockets
    - some welding on the frame (broken coil mount and replace steering stops)
    But, you know how these things go:
    - if I have the swinger off for bushings, I should repaint all that stuff since somebody went nuts with a
    - if I have the forks off for a rebuild and the rear suspension off, I'm about 10 bolts away from pulling the engine and painting the frame
    Anyway, I have the rear suspension apart and wanted to compare the swingarm and dogbone with some of my assorted spares.
    Turns out, my swingarm is just under 2" extended.
    Also, I learned about some Tecate rear suspension differences you experts probably already know:
    - 84 and 85 dogbones are different, 84 is shorter and it looks like my custom one is an 84 extended to about 3/4" longer than the stock 85
    - 85 bolts have grease fittings and the dogbone bearings can be lubed but the 84s do not have zerks or easily greaseable bearings
    - 84 v 85 carrier mounts attach differently
    STL
    3,560
    sounds ilke you have some serious work to do before rampage! you got 2 weeks lol. And i hate how it works out like that; take a few parts off and somehow end up rationalizing a full tear down to redo the entire bike lol. good luck! in for updates
    Jul 2012
    Seattle, Washington
    1,543
    I spoke with atv-innovations today and they said they have in stock Red Low Pro Maire fenders. The guy said Maire made some molds for the T3. I've never seen the red ones up for sale lately, not sure if that's what you need?
    It looks like your all set up for swapping different shocks with that collection of parts. Do you know what that shock is from? I've been wanting to try a banshee shock, I heard its a bolt on deal.
    Last edited by 3 Wheel Drive; 04-19-2014 at 11:25 PM. Reason: It was atv innovations w/ the red fenders.
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by jb2wheels View Post
    ...my swingarm is just under 2" extended.
    Hello jb2wheels;
    I like that length, it's close to what I ran on my race bike.
    The rocker and shock are different also between the two years.
    The 84' Tecate was made in a rush and by the time the first prototype was built and we had tested it and determined the rear bottomed excessively, it was too late to redesign the suspension links so we had to modify the shock to get it to work as well as possible. One of the band aids installed to reduce the bottoming was a VERY long bottoming cushion. If you look at an 84’ shock the cushion takes up around 1/2 the shaft length, lol.
    This was one of the issues we addressed in 85’. I ended up using a different rocker ratio and the link and shock were designed up around that.
    I suggest you use the 85’ set up of you have it otherwise the frame will bottom out on large jumps and your feet will smash the ground, lol.
    84 rod . . - 46102-4008
    84 rocker – 39007–4006
    85 rod . . - 46102-1128
    85 rocker - 39007-1078
    84 parts “fish”
    http://www.xtremeusa.com/OEMpartfind...1984/080182D-6
    85 parts “fish”
    http://www.xtremeusa.com/OEMpartfind...1984/080182J-6
    Hope some of this info helps.
    Jun 2009
    Leander TX
    2,217
    Quote Originally Posted by 3 Wheel Drive View Post
    I spoke with Chaplin Kawasaki or atv-innovations today and they said they have in stock Red Low Pro Maire fenders. The guy said Maire made some molds for the T3. I've never seen the red ones up for sale lately, not sure if that's what you need?
    That's interesting. I should call them. This Tecate has a set of cracked up Red Maier low pros on it now.
    I have 2, 85 Tecate shocks. The one on my parts trike has damping but the reservoir is damaged. The one on this trike literally drips oil on the floor if it sits shaft side down. I have a seal kit for it and thought I would try a rebuild since I've never done it before.
    I also have a Banshee shock on the way
    NO-SCALES's Avatar
    NO-SCALES is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2013
    DFW - TEXAS
    225
    You gonna have it ready in time? Sure wish i could make it
    85 Honda 250sx- STILL IN PIECES!!!
    84 Honda 185s - traded off
    85 Yamaha 225dr - parts machine for now
    83 Yamaha tri-zinger 60cc - my sons first 3wheeler. $300 for zinger, $4000 for a broken leg, memories for a life time - PRICELESS
    85 Honda Big Red 250es - traded off
    86 Honda 250r - traded off
    85 Kawasaki Tecate - new toy
    84 Honda 200m - super clean puttin around toy
    Jun 2009
    Leander TX
    2,217
    I'm cutting it close!
    It's completely down to the frame now. Frame and other black bits (pegs, shock mount, triples, bars) painted with epoxy today.
    I'm not touching the engine. It ran good when I got it and the piston & cylinder look great through the exhaust port. Although, I sent my flywheel to jeswinehart for some preventative work and he turned it around in days. Excellent!
    I rebuilt the shock today. I've never done that before. Good thing I had a spare shock - the piston in the reservoir had a hole in it. Unfortunately, I don't think the new seal will last long - the shaft has some significant wear on it. Regardless, it was a fun experiment. I have a Banshee shock for a backup when this one pukes again.
    I rebuilt the Forks, too. No surprises there since I already had useable tubes and new seals ready to go.
    More painting tomorrow. And swingarm bearings. I might actually start bolting pieces back on it.
    Jun 2009
    Leander TX
    2,217
    Nuts - I had to work late a couple of nights this week so no working on the Trike those nights but:
    Monday:
    Clean parts waiting:
    I put the stock sock I rebuilt back on with the Banshee spring. Here's why:
    It's a little longer and a little heavier. The stock Tecate spring is approx 5 kg/mm and the stock Shee spring is closer to 5.4 kg/mm. With a +2 arm and heavy rider, I probably need a significantly heavier spring but this is what I have.
    Here's where I left it Thursday night:
    Back on 3!
    Dec 2003
    303
    Looking good!
    -Chad
    Jun 2009
    Leander TX
    2,217
    About as done as it's going to get. I still need a couple of parts for the front brake - the little rubber seals/mounts. Should have them today.
    Runs good. No leaks yet. I mixed up a batch of 20:1 since I have no clue about the history of the trike. Seems to like it.
    Runs the lights with no problem.
    Fenders suck but they always did.
    Jan 2013
    minnesota
    5,911
    Hello;
    It's looking good.
    Unfortunately, if you plan to jump it that 5.4 will be to light especially if you are using the 84 link and not the 85. If this is the case, it will bottom out like a pig dropped from a roof. That 5.4 approximately compensates for the additional length of the swing arm.
    All you can do if it bottoms is run up your preload, max your damping and install a long bumper on the shock shaft.
    The spring you need is 5.8 p/n 92081-1857 but they are no where to be had.
    If you need a stuffer spring and can't find one, Eibach can make one for you, just call their toll free number.
    http://eibach.com/america/en/support/contact-us
    Jul 2012
    Joplin, MO
    597
    Don't let scuba on it. He will break something.
    Jun 2009
    Leander TX
    2,217
    Quote Originally Posted by The_Steve_Man View Post
    That green trike was a fickle bi...girl. Really messed him up good.
    Jun 2009
    Leander TX
    2,217
    No doubt this spring is wimpy. I'm all 85 for the rear suspension but I'm closer to 300lbs in full gear than I should be and probably need something closer to 7 kg/mm. I'll sort it out someday.
    ON the plus side, both the front and the rear are under sprung for me so it balances out
    Not much jumping for me. The air time is fun but the landings...
    Hello;
    It's looking good.
    Jun 2009
    Leander TX
    2,217
    Just got back from Rampage 2014.
    This Tecate is a LOT tamer than the foot breaking green one I sold last year. I don't know if it's just a tamer engine or the +2 arm but it's a lot easier to ride.
    It ran great all weekend until I moved the shifter to accommodate the new boots I bought. I could not get the shifter to stay in place after moving it. The splines are crap on the shifter but it was fine before I moved it. Nuts.
    The light looks great and makes a lot of light, but I'm not sure I like the pattern. I might change it before the next dune ride. I like the pattern on "The_Steve_Man"s 250R better.
    The shock is not great. The damping is wimpy. I expected a weak spring (confirmed) but it has almost no rebound damping. I must of screwed something up. I'll try the Banshee shock next.
    The damn swing arm pivot bearings are shot already. Something's not right. I had a hard time getting one into the arm. I bet that's the bad one. I'll have to take a look when I get it apart. I have a stock arm but this thing is so much nicer to ride than the other one's I've had I hate to go back. We'll see.
    I have lot's of time before by next sand trip. Maybe OK in October? Maybe Glamis in March? We'll see...
