Thread: pressing out stems on 250r
    mohave valley, az United states
    177
    Pushing down I assume. 20 ton press but was having trouble getting everything straight in the press. any ideas to make this easier.
    They are an extremely tight fit. I keep 2 pieces of 1" steel just under the edges of the stem and it takes allot force, but they will come out and a little heat on the aluminum helps.....
    177
    and its pressed down thru bottom correct? thanks dirtcrasher
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,237
    they are REAL TIGHT!!! I USE A PIECE OF PIPE ,, then heat the aluminum up fast and go quick... I have ruined a couple because they are in there so tight... and YES OUT THE BOTTOM,,,,
