My son twisted his kickstart shaft off at the edge of the kicker. Does anybody have the shaft or a bottom end for a 86' 200x? Maybe know of a replacement shaft from another bike that would work. Thanks Bob
86' 350X
86' 200x
07' dodge quad 5.9 cummins
13' subaru crosstrek
Place an ad in the "ATV classified" section under "The Goods" here on this forum and someone may contact you with one for sale. Be sure to state WANTED on your thread title...Dont know if anything will interchange. Also make note there is a larger shaft on 87 models so be aware of that when buying.(measure the diameter of yours)
Previously Owned:
1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
1981 ATC 185S
1984 ATC 250R
1981 ATC 250R
1983 ATC 110
1969 HONDA MINI TRAIL 50
TRIKELESS
86' 350X
86' 200x
