Ok, I've got this project almost done and I wanted to share it. This was started in another thread about LED headlights. I bought two of these CREE 6-emitter LED lights from Online LED Store's Ebay store:
http://www.ebay.com/itm/4-18W-1-600l...f2548e&vxp=mtr
I bought one spot and one flood. The plan was (and is) to use the flood as a low beam and the spot as the high beam.
Here they are mounted up. My 84 Tecate is the only one I've ever seen in real life (sheltered, I know), so I don't know if it's stock, but I've got a little shelf with ready-made mounting holes on the radiator guard. It isn't centered, which I admit bugs my sense of symmetry, but it was too good a location to pass up:
That was the easy part. Then I had to get some stable DC power to run them. So I bought this Trail Tech Regulator/Rectifier on Amazon:
http://www.amazon.com/Trail-Tech-700...ator+rectifier
You can just see it in this picture. It's mounted underneath the standard round electrical plate:
Then I had to add a headlight switch, and while I was at it, I replaced the crappy tether-style kill switch:
http://www.amazon.com/Technologies-H...adlight+switch
Here's a picture of the switch on the trike:
The bad news is that the switch is defective, and doesn't work in the high beam position unless you have it just in the right spot.
Then there's the wiring. I was thinking about using an outlet box of some kind and just stuffing the connections inside. Then I was inspired by Flyingw using a terminal block on his awesome 70 project, and decided to go that route. It makes troubleshooting easy if you have a problem, and also if I want to add a taillight later on. Note the round electrical plate mounted to the holes where the airbox would be. Since I don't have an airbox, this was the perfect place.
Last, I used a big old computer capacitor that has to be there for the regulator to work properly. Trail Tech recommends their battery that costs $50, but I didn't really see the point. My mounting leaves something to be desired here, so that may need to be redone. I also noticed that something already pinched one of my wires, so I might need to do a little re-routing to the capacitor. BTW, I didn't do that horrible thing to the frame, it was that way when I got it! That not-Kawasaki green paint too....not my doing!
...and finally, here's one with one of the LED headlights actually working. I am very impressed with the amount of light they throw.
What's left to do is replace the bad headlight switch, and then run a diode between high beam and low beam so that when the high beam switch is on, both headlights are lit.
