Results 46 to 49 of 49
Thread: Best Tires for a 250SX
  1. #46
    Jun 2014
    Southeast Missouri
    64
    Has anyone ever run an ITP Mud Lite (23x8-10) up front?
    It would look cool if nothing else... as well as matching the rear tires. I was thinking about mounting it on a 5 inch wide 3+2 offset Douglas polished aluminum rim. The 10 inch diameter should allow adequate space for the valve stem on the brake drum (left) side.
    Any thoughts (or possibly pics) of a similar set up?
    Also… still looking for confirmation that a 200X front fender will bolt directly to the forks of a 250SX without modifications?
    Current Trikes:
    '86 350X (x2)
    '86 200X (x2)
    '86 250SX
    '85 250SX
    '85 250SX / 200X Hybrid
    '87 250ES
    '85 250ES
    '83 ATC 70
    Current Quads:
    '16 Polaris Outlaw 110
    '14 Polaris Ranger XP 900
    '13 Polaris Sportsman XP 850
    '07 Honda Recon ES
    '05 Yamaha Raptor 80
  2. #47
    Jun 2015
    Arizona
    69
    So what would you guys recommend for a hard pack Arizona desert with sandy washes and then the Cinders OHV area which is volcanic fine pebble rock that you basically treat like sand. Last time i had an ATV it was Minnesota with good old Wolly Boggers and a stock front.
    I am going to do doug's front wheel swap and am thinking of using the Kenda Front K284 Max.
    Keeping with the stock rear wheels I was just thinking of defaulting to the Duro Mud and Sand (basically the new wolly Bogger).
    Thoughts?
  3. #48
    Sep 2005
    MICHIGAN
    2,026
    I had Maxxis Sur Trak on a quad which are now the Kenda Bear Claw. I would only recommend them as a rear tire, but the biggest problem with them along with Spider track like tires is they weigh a ton. Way too much. they can be reversed for a sand paddle mud type tire but they rob power. They were a fairly tough tire though.
    I had a Kenda front Max on a 3 wheeler and thought that worked good.
    86 T3
    84 T3
    86 KX250
  4. #49
    Aug 2020
    Prescott
    Doug, I’ve been doing some major research and just can’t find anyone who has run a 24 or 24” tire on the front of a 250sx. I’ve seen the ES with a 12” wheel and 25” tire, but I don’t know if that will match up to an SX front end. Any help please?
