Well guys, there are a few teeny tiny details to button up but I'm considering this machine complete. The details that I'm going to handle do not effect the overall look of the bike so I'm going to share these pictures with you all today. I'm also going to update the build thread but I wanted to start a new one for these final pictures. Big thanks go out to our fellow board member blue27, aka, Bruce at BlueLine Graphics for making and helping me install the awesome decals on this machine today!
I also need to mention once again Kain (whtcamaro) and Pat (vealmonkey) for wiring assistance, flossy for the donation of the key switch dash panel and Jonathan (xowner) for the awesome wheels and tires plus assistance sourcing many parts. Derrick Adams also helped out getting some speedy powdercoat done last minute for the build. Thanks also go out to the whole community here at 3WheelerWorld and other forums as well. Remember, the community by supporting these builds every year helps fund Trikefest trophies, port-a-johns, t-shirts, hats, our drag lighting system and a slew of other lesser known details of the event and even our forum here.
This build started life as a bone stock Honda ATC70. The frame was stretched 3 inches and a brand new larger size metal tank was sourced from japan. The machine is powered by the incredibly powerful, Piranha 150cc manual clutch, electric start pit bike engine. To soften the ride a replica of the old school A+ suspended frame front end was put together and was complimented by a 7" Honda CB headlight. The headlight really brings an old school duner flare along with the vintage inspired decal striping. A battery compartment was added in frame along with mounts for the CDI and solenoid to keep the electrical neat and tidy. A complete end to end wiring harness was fashioned using VintageConnections connectors and insulator boots; these are OEM jap spec connectors crimped on just as they would have been at the factory.A 87 atc200x key switch dash replica mounts a 400ex key switch adding a touch of security and a pocketful of cool keys for this cool machine. Every item was either replaced or refurbished. A large amount of brand new OEM hardware was sourced along side of the many re-plated items. A brand new seat, consisting of new metal pan, new foam, and a strong excellently styled cover provides a coosh saddle. To make sure the brakes were up to par to stop a machine equipped with a large powerful engine a custom rear hydraulic disk brake setup was put together, of note, this setup is completely bolt on and could be returned to OEM drum unit if it was so desired. The PRM grab bar mounted out back really makes loading this thing in and out of a pickup truck a breeze. To provide tool-less chain adjustments a spring loaded chain tensioner was added in place of the stock bolt on unit. The icing on this machine is the outstanding decals provided by Blue Line Graphics. They were developed with a vintage flare reminiscent of the old school pin striping present on so many hard tail machines out of the 80's. Whomever takes this machine home can be sure that they will have a head turning, smile inducing machine the whole family can enjoy.
Any one can end up owning this machine, need not be present at TF14 to have this machine.
You can participate via the 3WW Shop here, http://shop.3wheelerworld.com/produc...?productid=227
