Results 1 to 9 of 9
Thread: Deer lease 83' 200ES Any help? Any help at all?
    dman10's Avatar
    dman10 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2013
    Elgin, TX
    402
    I have a 1983 200ES with a locked up motor. And a 1984 200es motor I'm using.
    Now I have questions,
    1.) Do gaskets matter between 83 and 84?
    2.) Can I rig a basic starter system? Like battery->key->starter? If so, how?
    3.) Will my rough hill country deer lease destroy a 2 ply front tire? Should I go with like a 4 ply?
    4.) Best way to carry a deer? Front rack?
    5.) Will regular spray paint just cook off of the engine?
    6.) Anything else? I should know?
    I'm going to put new bearings front a back and completely cover the chain(Missing outer guard)
    And keep a spare at the lease.
    Thx,
    "D"
    Attachment 197624
    Quote Originally Posted by tri again View Post
    Cool stuff seems to happen when I'm sleeping.
    Nice to know things happen without me.
    dman10's Avatar
    Jul 2013
    Elgin, TX
    402
    Also, Any recommended gaskets brands?
    dman10's Avatar
    Jul 2013
    Elgin, TX
    402
    I went to move the 83' today, need room to do a motor swap in my ranger, and noticed it was moving really hard. By the time I moved it across my garage slab, I was panting, it was that stiff in the rear end. What does that mean? The rear bearings are bad and it has been sitting for awhile, and does running it out of oil put my trans at risk? Or...
    Mar 2012
    mantua, ohio
    88
    you've got me stumped on this one, 1983 200es was chain drive, 1984 200es is shaft drive, not sure how you made the swap?, but would like to know. If it helps, i have a good 1983 200es engine less the top end, would be pricey to ship though...............
    dman10's Avatar
    Jul 2013
    Elgin, TX
    402
    Quote Originally Posted by bigred22 View Post
    Swap the transmissions...
    Mar 2012
    mantua, ohio
    88
    didn't know that could be done between these engines, any pics of the swap?
    Feb 2014
    Victoria,Australia
    878
    I don't understand how a chain drive tranny can interchange with a shaft drive tranny?? also if you run your engine it will affect your topend more than your tranny your piston will chew itself to pieces or seize up.
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
    Apr 2014
    Edmond, KS
    2,534
    I guess you'll find out about the tire. If it's very rough, I'd try to find a trailer to haul your deer with.
    Chopsaw is offline Just Too Addicted Arm chair racerJust too addicted
    May 2013
    St. Louis
    505
    83 is a 200e ,,, 84 is a 200es . Seems to me you might be taking on more than you can handle . Good luck .
