Results 61 to 75 of 88
Thread: Louis's trx400ex to atc400ex conversion build
  1. #61
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Nice looking build Lou!! Can't wait to see it completed! You sure put alot of time into it!
    TF 07,08,09,10,11,12,13,14!
  2. #62
    Maryland
    3,077
    Thank you for the kind words. I try to be my own worst critic. If I point out my own flaws not much left for others to point out right? Lol all I can say is I'm getting better and it won't fall apart, that is for certain.
    Quote Originally Posted by thcowboy View Post
    Wow well tig is really hard compared to mig or even arc (thats me) and you actually have some good welds for not being exoerienced with tig
  3. #63
    Louis, as usual your projects come out fantastic.
    I also share this. I have owned a 2500$ Miller TIG for a year and I STILL CANNOT WELD ALUMINUM!! I have tried and tried and walk away hating myself I bought TIG welding for dummies, specific Tungsten rods for Al, one green wheel ONLY for Al and grinding the snot out of the coating to clean it spotless.
    So, please, no one ever send me anything aluminum to weld,
    You are one persistent driven man and I have huge respect for that!!
  4. #64
    Jan 2011
    Brazil, Indiana
    2,087
    Whoever told you that you go a bit overboard with the gussets and such, I'd have to agree with them.
    If the water truck at Haspin breaks down, he can use the reverse and tow it back to the barn with the front end. 😋. I don't belive it is overkill, some may laugh and joke about it now, but no one will laugh when it doesn't break or buckle. I don't know about anyone else, but I'd feel like a fool for not taking the time to sturdy it up and have it fold up like a lawn chair off of a jump.
    Build looks great so far. Don't get in a hurry and muck up all of the great work so far.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
  5. #65
    Dec 2014
    Hoffman Minnesota
    135
    Updates?
    1982 big red
    1974 atc 90
    Life is hard, but its harder if you're stupid - John Wayne
  6. #66
    Maryland
    3,077
    Well honestly I wasn't planning on updating until after I had the oil tank done but since you asked lol.
    This past week I got the oil cooler mount built.
    It's fairly simple, I took some 1/2" thick cold rolled rod and heated it with an acetylene torch in order to bend it to shape. I was going for a shape similar to atc250r radiator brackets. I think I succeeded.
    Then I made a pattern of the side mount, transferred it to some plate, cut it out with a jig saw and added some decorative speed holes, and welded it up. (pics show it tacked but i did finish weld it)
    Mounted up!
    Go to need to make some adjustments when I run the oil lines but otherwise a good fit.
  7. #67
    Maryland
    3,077
    I had previously finished reworking the front tank mount, made it smaller and welded in the threaded insert for the bolt that screws into the frame.
    I also worked on some shroud relocating brackets as the shrouds needed to be in thier final position before I could build the oil cooler mount.
    Due to the placement of the tank,the shrouds sat farther forward then I was really happy with. Unfortunately this was necessitated by the fact that the shape of the bottom of the crf tanks limit where they can be mounted specifically. The bottom of the tank needs to clear the head while remaining somewhat level so that no one portion of the fuel tank is in the lowest position. If the tank is tilted too far back it creates a "unreachable well" where fuel would sit but never be reached when the tank was empty to the fuel line bung and screen. These considerations placed the tank a bit too far forward in relation to the head tube. The tank itself wasn't a problem but the shrouds were another matter. The forks made contact with the shrouds at full steering lock and that wasn't acceptable. I also wanted the backside of the shrouds to sit out further to be more contoured with the sides of the seat so ultimate the answer to both problems was to come up with some brackets that mount to the tank which relocated the shrouds to the correct position.
    These were fairly simple to make as they are some thin flat bar stock bent to the contour of the tank, with mounting holes, nuts, and spacers welded together.
    I don't really have a good before picture but take my word for it, the sides of the seat hung over the sides of the shrouds considerably. This fit is much better.
    A note, the bung that will hold down the front of the seat hasn't been completed, once in place the front of the seat will be pulled down against the tank securely.
  8. #68
    Columbia
    5,131
    That's real nice Louis.
  9. #69
    Dec 2013
    Greater Vancouver, canada
    55
    nice work you definetely have some great fab skills
    shame those welds arent as nice. as a welder i can honestly say that it is harder to fab than it is to weld. why not mig weld it? not like the materials too thick
  10. #70
    Maryland
    3,077
    Well in truth the plan is to get better at tig welding, only real way to do that is to well, do it. lol. Sadly welding coupons together gets old fast am I right?
    Quote Originally Posted by Jones View Post
  11. #71
    Maryland
    3,077
    Well had some more time to do some more work. First up I attached the steering stop. This is rough fitment and is subject to change.
    Next up did some major work on the oil tank. It's not complete yet but the hard part is done. I started by making several cardboard and paper versions of the tank until I was somewhat happy with the fitment and then I cut out the piece from aluminum and put them together.
    The tank is mounted up with rubber grommets and bushings similar to how radiators attach. I've left plenty of room for the triple tree/fork to clear as I still have some final adjustments to make for the steering stop/full lock. Not a whole lot to say otherwise. I'll just post up the pictures. I think I finally got a handle on the aluminum welding. Can only get better from here out.
  12. #72
    Maryland
    3,077
  13. #73
    Maryland
    3,077
    That's pretty much it for now. I need to do some work on the steering stop. Need to get a little more rotation out of it. I'm thinking I may have to adjust the oil cooler mount. That'll suck but hey, what needs done needs done. Next will be shaping the metal to fill the cutout in the oil tank and making sure it doesn't leak. That's going to be interesting. Then I can focus on plumbing the oil lines. Slowly but surely marching towards a ride able machine. Can't wait!
  14. #74
    Dec 2014
    Hoffman Minnesota
    135
    So the 400ex has a dry sump oiling system and thats why you need the oil tank, right? Sorry for the dumb question.
    1982 big red
    1974 atc 90
  15. #75
    Surprise, AZ
    2,428
    I was thinking maybe 3-4 holes drilled through the tanks face with 1"-1 1/2" tubing welded in would look trick, run cooler and make good use of your tank shrouds.
    Oil tank radiator if you will.
