Got a couple of packages today! Wire and a bunch of connectors. Built a wire harness board (helps a ton!) and stripped down my beater 350x wire harness down to the wires, and found a couple of bad spots where it was being pinched by the air box >,<.... it needed a harness more than I thought. Harness isn't done, but ~95% done, waiting on a special tool for the coil connecters, and I bought the wrong sized ring terminal for the frame ground. Here are some photos, 3 of the harness on the peg board, and the nearly complete harness.
I did the math... and I can sell the 350x wire harness for $65 + shipping. I have supplies for 1 more, first one is going on my machine . I won't be able to ship one out for around a week as my service manual didn't match the color scheme, so I had to use a wrong color wire to make my current harness.
I would be more interested if you allowed certain mods to be requested.
IE... a battery input for a 350x, or a functional tail light, or dash lighting, the addition of a keyed switch, and so on.
These things help.
Feedback thread: http://www.3wheelerworldforums.com/s...ad.php?t=78535
Patiently waiting..
I have no problem with custom requests, the only real problem is placing the connections correctly on the harness, and I would probably have to have photos of the connections so I can color match and match the connection types.
By functional tail light, you are talking about one hooked up to a brake switch that makes it get brighter when you hit the brakes?
So do you sell an 86 350X harness?? Or are you still looking for interest/buyers for it??
I have supplies to make about 3 more, I haven't made time to finish the first one I was working on, the tool I got for crimping the "flag" connector for the coil isn't as good as I hoped for. I might have to buy a 60-70w soldering iron and fold the tabs over and solder it since I can't get a good crimp.
To answer your question, if someone is interested in buying one, I can make it, but I don't have any pre made for shipping so there will be a small waiting time.
I just got home from my parents house where my nice 350x is and I noticed it's wire harness isn't as nice as the rest of the machine , going to have to make one for that too I think lol.
1978 ATC70 w/ Piranha 140cc
2017 YZ 250x- Braap
I'd be up for a '82 250R harness. Since I am doing the restore that would be perfect. I'm an idiot when it comes to making
something like this.....and most things.
"See, morbid and creepifying, I got no problem with, long as she does it quiet-like. "
Trikes:
1982 Honda ATC250R(in process), 1984 Honda ATC110, 1984 Honda 200s, 1985 Kawasaki KLT160(not running...yet)
Quads:
1990 Suzuki LT250S, 2013 Suzuki LT-Z400, 2014 Honda TRX450R SE
Where are you buying OEM style connectors if you don't mind me asking?
2017 YZ 250x- Braap
I buy most of the connections from http://www.cycleterminal.com. Joe is a great guy to work with, and very prompt on responding/shipping. Prices are probably a little higher than other places, but all of the connectors I have bought from him so far have been really nice quality.
Just in case anyone is interested, I use GXL automotive grade wire. This wire is certified up to 125C and resists weather, oil, and grease, typically is used in the engine bay of a car.
FYI, the OEM style terminals and connectors require special tools to crimp. I haven't found an inexpensive "flag" terminal crimper yet, cheapest being like $100. I have a tool that does ok for the current time.
Sounds good buddy, I may buy your first set if it looks great and functions perfect.....
I would probably be interested in an 85 250r harness. I don't know if i'll ever have time to make one. Though it does looks kinda fun.
2017 YZ 250x- Braap
I took a quick peek on ebay, and it looks like there is two styles used for the CDI plugs, the single plug 6 pin connector that I can't find a source on, and the 2 plug 4+2 style connector that is common through present. If yours is the single 6 pin connector, I'll need at least the connector sent to me to reuse the outer shell/holder of the pins as long as it is in good shape. I can get the rest of the connectors new.
Here is the 1982 250R harness I made today, photos didn't turn out the best, for some reason the flash didn't go off. The taillight wire is about 8 inches longer than stock as requested. I jumped the gun a bit early and started putting connectors on it, so I couldn't put the tubing on it. It is electrical tape warped instead, and this isn't the cheap electrical tape found in most stores, this stuff is $6.50 a roll and safe up to 105C. If you prefer the tubing, I can make another one and offer this one up for sale.
Total will be $75 including shipping. I'll pm you payment details.
