Results 1 to 15 of 16
Thread: 85 ATC 110 No spark
    Dustin87R is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2007
    Maysville, Georgia
    192
    85 ATC 110 No spark
    I've got an 85 110 with no spark at the black and yellow wire coming from the CDI box to the coil. I have replaced the CDI box, coil, cleaned the flywheel, stator and set the gap on the pulse generator but can't get power to the coil. The CDI and coil was removed from my running 110 so I know they're working properly. Does anyone have any ideas on what the problem could be?
    Jan 2014
    La
    1,062
    have you looked at the spark advancer if its broken you will not have spark.
    May 2007
    Maysville, Georgia
    192
    That's the spring loaded plate under the cdi cover on the head right?
    Jan 2014
    La
    1,062
    Yes that's it .
    May 2007
    Maysville, Georgia
    192
    It seems to work just as good as the one on the running 110 and I have power coming from it when I turn the engine over. I got intermittent spark when I first started working on it but now I've got nothing. I also changed the kill switch and checked the grounds.
    Apr 2012
    USA
    4,114
    Do you have a Ohm meter? The service manual has the specs what the coil should read as well as how to test the stator and the pulse generator, let us know what your readings are. Since you know the CDI is good, I'd say you can skip the test process on that.
    One other point to bring up, how about the spark plug?! I have had experience with spark problems, and it ended up being the actual plug even if it don't look *that* bad.
    JustEnough's Avatar
    JustEnough is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    Elk Grove, CA
    333
    Intermittent spark may indicate corrosion at the wire connections. Wire brushing the connections may get it working and then go back and put dielectric grease on those brushed connections to prevent future problems.
    6,726
    Most likely the stator . Here is the correct one and its easy to replace .
    http://www.ebay.com/itm/231323590522...%3AMEBIDX%3AIT
    May 2007
    Maysville, Georgia
    192
    I checked the stator and pulse generator today with the ohm meter and they were both in the same range as the ones on the running 110. The link for the manual didn't work for me so I just compared the readings from the running trike. I've checked the entire harness for broken wires and cleaned all connections but still don't have any power to the coil. I've been working on these things for years but this one really has me scratching my head.
    Apr 2012
    USA
    4,114
    The service manual auto link goes to a thread on here, the last page has a working link.
    There is also this site: http://www.atcmanuals.info/
    When you get to the manual link, it would be best to right click -> save link location.
    Austin, Massachusetts
    1,591
    need a stator for a 110. Shortline, the link above is old. any recommendations? or just surf ebay?
    Wubba Lubba Dub Dub!!!!!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    85 Yama 225DX - The Rental!
    150cc Piranha powered 70
    110cc Lifan 70
    82 70
    83 ALT 50 Trail Buddy
    88 Yamaha BW 80
    84 z50
    Apr 2012
    USA
    4,114
    Quote Originally Posted by redsox View Post
    What year is your machine? I'm pretty sure I have a 79-81 era atc110 stator around yet. Most of the time ebay or buying a parts machine is the easiest way to find used parts. Some select parts you can get from Honda, and some aftermarket, but most parts it will be used market only.
    1,591
    sorry for the late response. Its an 84 110.
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    110cc Lifan 70
    82 70
    88 Yamaha BW 80
    84 z50
    6,726
    The 83-85 110 will use the same stator coil as the Atc 185-200 models , you will have to soldier it in .
    1,591
    So, I had an old 200s parts motor that I got from that Maine-iac BrenDown like five years ago. Last night I took the stator from that and soldered in the swapped connectors. Nice blue spark!! Awesome. Thanks for the help. Cost = Zero!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    110cc Lifan 70
    82 70
    88 Yamaha BW 80
    84 z50
