185s gearing/ chain cover
Hello all im new to this site and 3 wheelers. I have used the search feature but i cant find much about what im looking for. I want to re gear my trike to give it more bottom end. I am assuming my sprockets are stock size but im not positive. I feel like its geared way to much towards top end. I want more torque but id like to keep the chain cover on. What is a good sprocket combo to get this thing spinning the tires and revving higher. If i re gear it to a bigger rear sprocket will the cover still fit? Also what is the stock sprocket combo?
Thanks for your help
Edit: i found the stock gearing to be 11/41. I have found a 10t front sprocket so whats the biggest rear i can fit with the cover still on?
Oops.. If a mod gets a chance could you move this to the new member discussion... Or trikeslvania if you want to take me off probation early... Hahaha
//ArrowChat Integreation Code
