Results 1 to 15 of 26
Thread: Old member just back after many years
    Oct 2014
    TOLEDO, OH
    212
    Hi everyone ! I used to be a member on here a long time ago, I think I even sold my tri-z project to someone on here tri-z Jim maybe? That was years ago and I'm back now with three Honda 110 and a astro converted 86 tri-z , the tri-z I was looking for more info on the conversion kit but haven't found much on it. To be honest I hated the four wheel kit at first but finding it kind of rare I want to fix it up and keep it the way it is.
    Slidell, LA
    4,737
    Welcome back
    florida
    186
    Welcome back, Do you have any pics of the converted triz
    Oct 2014
    TOLEDO, OH
    212
    Quote Originally Posted by whitetail hunter View Post
    Thanks ! Sure do will put some pics on tonight
    Oct 2014
    TOLEDO, OH
    212
    1985 atc 110
    Oct 2014
    TOLEDO, OH
    212
    1985 110 another pic
    Oct 2014
    TOLEDO, OH
    212
    Quote Originally Posted by Naturalbornbikr View Post
    The other photos keep getting flipped upside down when I try an load them, will try again later ! Thanks
    Oct 2014
    TOLEDO, OH
    212
    While I'm trying to figure out how to get the rest of the pictures on here let me share the story of this 1985 atc 110. I bought this for $400 because of the nice shape it was in and the fact it had a title. I really didn't spend any time looking it over I just handed the cash over and loaded it up. Brought it home and noticed it smoking a little and thought no big deal but it was leaking oil pretty good and at first could not pin point it. Well after looking it over I found oil was coming from the air box, yep blow by. So tore the motor apart found the clutch wasn't put in right which caused damage to the primary gear, and some other parts, piston was shot which I had a hard time finding a new one. I had it bored to the next size up due to cylinder damage at our local shop, So far I purchased new clutch plates, springs, complete gasket kit, front and rear sprockets, chain, carb rebuild kit, new piston kit, new shindy valves, and new brake pads. Started putting it back together found out I have the wrong valves and the cylinder was bored out to small for the piston as there is no ring gap. So right now I'm waiting on that.
    Oct 2014
    TOLEDO, OH
    212
    Here are the valves and you can see how they are different. The part number is right but the valve keepers won't hold it right.
    Oct 2014
    TOLEDO, OH
    212
    Here is the pic
    Oct 2014
    TOLEDO, OH
    212
    1984 110, bought as a parts bike but cleaned it up and she runs so I started fixing her up!
    Oct 2014
    TOLEDO, OH
    212
    Another pic, this one came from a farmer , it has sat for years the stator cover off so it was all rusty, rear bearings shot, replaced stator, new air filter, cleaned carb, new rear bearings , upgraded brake drum to a trx125 drum , new brake pads and still have a lot to do but it runs and the lights work!
    Oct 2014
    TOLEDO, OH
    212
    1986 tri-z with the astro conversion kit
    Oct 2014
    TOLEDO, OH
    212
    I found the issue on that valves, eBay has listed all these valves work for 1979 to 1985. They will work for those years but the valve retainers are different 79-83 than 84-85. So to use these in a 1984-85 model you have to have the older 79-83 style valve retainer.
    Oct 2014
    TOLEDO, OH
    212
    Picked up another 1986 tri-z today will post pics tomorrow
